Paininting non-skid... - Page 4 - SailNet Community
post #31 of 37 Old 01-27-2008
Midwest Puddle Pirate
US27inKS's Avatar
Just remember if you're spraying a two-part LPU paint, you're spraying cyanide-based chemicals... and you best have the proper respiratory protection gear or you could end up DEAD.
Absolutely. You don't need a pressurized hood, but if you have one available that would be great. Just make sure your mask fits properly and has new cartridges. Make sure the cartridges are compatible with the paint being used. If you're not sure, call the paint co.
If your mask has a leak anywhere around the skirt (I have a big beak and it's a problem) you'll feel it in your lungs almost immediately. STOP - and fix the problem. If you have to walk away from a partially painted boat, oh well. Sanding and starting over beats long term health problems hands down.
US27inKS is offline
post #32 of 37 Old 01-27-2008
artbyjody's Avatar
Also note - some boatyards will not allow you to do it yourself unless you do it in one of their set-ups and have some kind of certification (or hire one of their guys as a consultant)....follow-up on US Pirates suggestion...
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #33 of 37 Old 01-27-2008
BTW, if you're planning on spraying a two-part LPU, you'd better have an enclosed facility to do it in... since you're be responsible for any problems the spraying causes to people nearby. Spraying a isocyanate-based paint without a enclosed building is a really bad idea.
sailingdog is offline
post #34 of 37 Old 01-27-2008
Certified Old Fart
I have worked in the "painting" end of manufacturing for 32 years so I have a little experience.
2K paints(isocyanate) are nasty things.
I am not going to make a "blanket recomendation" for your protection needs because a lot of people will ignore it any way. Just sufice it to say this is nasty stuff and there are long term effects from exposure and it CAN KILL you right away.
Ask the supplier for a MSDS ( material safety data sheet ) before you purchase the product. You can also usually find it on on a manufacturers web site. READ IT CAREFULLY!!!!!!!!! Decide if you really want to mess with it. Follow the PPE recomendations to the letter. If they say Supplied Air Respirator or Supplied Air Hood it is for a reason. This is one of the few times the Government is your friend. The manufacturer is required to provide this info to you. 10 minutes of reading is worth it.
2K paints are wonderfull things but the finished product is hard as a rock and almost impossible to sand. So unless you are a really good sprayer or have a lot of time on your hands for sanding, find someone who knows what they are doing.
With any painting that requires a respirator the "large beak" is a fit problem. So is any facial hair. To get a proper fit you need to shave it clean. At the least you will probably scare the neighbors and you wife will want to know who you are if she is used to seeing the mustache and beard.
Enough preaching. Sorry Rev.Mike. Just want everyone to be safe.
"Beyond here there be Monsters".......Captain Barbosa
CKDK08 is offline
post #35 of 37 Old 01-27-2008
No I dont remember
US27 great post on painting . thats the ticket , its all in the preparation . If people pay attention to your instructions then we will see a great improvement in DIY boat painting
All the best
Paul
Its hard trying to nap with that bilge pump alarm going off all the time
Raggbagger is offline
post #36 of 37 Old 01-27-2008
pigslo's Avatar
You need more then just a filter, you need a respirator, Otherwise you will glue your lungs together when spraying 2 part lpu.
pigslo
pigslo is offline
post #37 of 37 Old 01-29-2008
US27inKS's Avatar
If you do enough prep work, even a DIY paint job can come out pretty nice.
US27inKS is offline
Rib Skid RealityCheck Gear & Maintenance 2 09-02-2007 07:24 PM
Home made non skid for plates, etc geary126 Gear & Maintenance 4 05-27-2007 11:37 PM
non skid deck paint freddy4888 Gear & Maintenance 10 01-18-2007 01:39 PM
Restoring non skid decks Petar Gear & Maintenance 9 06-13-2006 04:23 PM
Need advice on non skid paint HeartofGold Gear & Maintenance 5 04-13-2004 06:44 AM
