01-25-2008
Arf!
Originally Posted by soulesailor
Pegasus~ are you sure they are blisters that popped? If you have craters after a blasting they may have been air pockets from the resin not fully penetrating the cloth in the original lay-up. I've seen this on my friend's boat. They were everywhere, dry as a bone. Originally they were bubbles between the cloth laminate and the inside of the gelcoat, very blister looking. The blasting might have blown off the gelcoat side of the bubble, leaving you with the craters. If this is the case you don't have to wait for your hull to dry, you can move right in and get to work.
After my initial panic, I began to wonder the same thing. I had my previous boat bead blasted about 9 yrs ago, and there were no such blowouts.
But I am inclined to agree with your diagnosis, especially since the surveyor went over the hull below waterline with a mallet and a moisture meter, and I would be surprised if he missed such widespread water intrusion.
So maybe the difference between the previous job and this one was the technique used in laying up the hull (different manufacturers) or the guys who did the blasting were more aggressive this time. I recall that last time after the blasting job I had a whole day's sanding to remove the remaining islands of bottom paint - all small, pimple-sized. This time the only bottom paint remaining is under the jackstands.
If the craters are not blister-related, then the repair consists of one afternoon with a spatula and epoxy filler...
Fluctuat nec mergitur
