Old 01-25-2008
ianhlnd's Avatar
A little less cheek
ianhlnd will become famous soon enough ianhlnd will become famous soon enough
Tuning the rig after
So, my whole ketch rig is down, shrouds, intermediate stays, triatic, everything. The main mast is being held up by jury rigged forestays and running backstays. The boat is a ketch, starting from the front, roller furling genoa and staysail, roller furling loose footed main and there is a triatic, New shrouds are being made up and now I have a question. How in the diablo do I tune this stuff, forget rigger, there's only one, and he has a 4 week backlog. I have to be in Mazatlan for Carnival on the 15th of Feb. with reservations at the Marina Mazatlan starting on the 5th.
I have just about every tool there is, including a Loos & Co cable wire div. tensioner.
How does one proceed? Alex, a ketch is a boat with the shorter mast in the back HELP, if this rig isn't ready, my first mate may bail.
Just checking in.
Where ya'll keep'n the wimmin 'round here?
Old 01-25-2008
bestfriend's Avatar
Hitchin' a ride
bestfriend is a jewel in the rough bestfriend is a jewel in the rough bestfriend is a jewel in the rough
There you are! Never mind all that! Sailhog is marrying Giu's boat and we need you to be the photographer.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
Old 01-25-2008
ianhlnd's Avatar
A little less cheek
C'mon BF, this is serious, not only may I miss Carnival, that's a money gig, but well you know, the benefits of a first mate also.
By the way, who's the bride and who's the groom?
Just checking in.
Old 01-25-2008
Ian send me a pm with the diameters of the stays shrouds etc.
Send me all the data you have, I'll calculate it for you.
Old 01-25-2008
bestfriend's Avatar
Hitchin' a ride
Sorry Ian, I'm a little goofy right now. I knew G would be here for ya soon. Best of luck!
Vaya con Dios
Old 01-25-2008
lastconch's Avatar
lastconch is on a distinguished road
Selden has a good booklet out check charleston spar website. basic are start with main cap shrouds plumb the mast port and starboard, setup everything only hand tight to start. then the set the fore and aft rake on the mast. next are the lowers. when mast is plumb both ways tighten all stays to 15% of design load. follow with mizzen. then go sailing and adjust as needed for helm and bend in mast, or rake. don't preload more than 30% of design load of wire varies with wire size. Brion Toss's riggers apprience is great reference on rigging.
Old 01-26-2008
Ian-
Technically, your boat is a cutter-rigged ketch... not just a ketch, or you wouldn't have the staysail setup.
What happened that the mizzen mast is down?? Did you break rigging or is this a preventative replacement???
Old 01-26-2008
mwrohde is on a distinguished road
I think he broke it. http://www.sailnet.com/forums/cruising-liveaboard-forum/39816-new-lessons-relearned.html
Old 01-26-2008
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
First, measure the mast to the toerail on both sides to make sure it's exaclty centered. Then use the Halyard to check plumb by running the halyard to one toerail and then across to the other toe rail. The halyard becomes your tape measure. The distance to both toerails should match. Then you are plumb and can continue on to the other steps mentioned.
Old 01-26-2008
Ahhh... he broke the head casting.. UGH... that sucks.
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Ketch/Yawl Handling svsymphony Seamanship 19 07-05-2008 01:19 AM
Sloop or Ketch? maxheadspace Boat Review and Purchase Forum 46 07-27-2007 02:56 PM
Yawl Info Needed sailortonyb1 Boat Review and Purchase Forum 5 01-18-2006 04:51 AM
