01-26-2008
Yes, it is a fairlead. You can use any number of replacement fairleads that you can find in any big chandlery. Don't recognize the brand or make you've got in the photo... and most of the better ones fully enclose the rope.
If you have to drill and tap new screw holes, use TefGel or Lanocote or Loctite to reduce galvanic corrosion between the mast and screws. Don't forget to use a plastic washer between any stainless hardware and the mast.
