Old 01-27-2008
fourgeau is on a distinguished road
Send a message via Skype™ to fourgeau
Change of cooling fluid on Yanmar4JH4 TE
I am at a loss to identify the drain valve(s) to change the cooling fluid on this engine installed on my Beneteau 473.
Yanmar recommend changing the fluid every 500H. i have not yet obtained a service manual and would like to change the fkuid which is low ASAP
Old 01-27-2008
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
Mine has some fairly obvious taps with clear plastic hoses attached mounted towards the lower rear of the engine block. The more obvious one is above the starter motor.
Jonathan-Livingston
Yanmar 1GM10 cooling system, needs a good cleaning. SVDistantStar Gear & Maintenance 4 01-13-2008 03:14 PM
Universal 5411 Oil Change saurav16 Gear & Maintenance 10 10-01-2007 07:16 PM
Understanding Apparent Wind Steve Colgate Learning to Sail Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Seamanship Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Racing Articles 0 11-10-2002 07:00 PM
