Old 01-28-2008
Irrationally Exuberant
arf145 is on a distinguished road
Strained Relationship with my Strainer
Actually, the strainer is fine--we're on excellent terms. Different story with the outlet...
Our boat's PO had a new raw water strainer put in for the Yanmar 2GM20F right before we bought it in September. The new one looks good--don't know the brand offhand, but it is bronze, sizable, has a clear viewing area and clamp-on top. It looks like the Perko ones I've seen, IIRC.
But the installation! The strainer outlet appears to be 3/4" pipe with a lip to take a hose and clamp. but the pump it goes to uses 5/8" hose. The boatyard solved this problem ingeniously: they slashed up and abused the end of the 5/8" hose until it would stretch enough to be forced over the 3/4" strainer fitting. To finish off this nice piece of work, these craftsmen just tightened the clamp down until it cut into the mess further.
I want to fix this potential disaster, but what's the best way? A barbed reduction coupling between a piece of 3/4" hose and the 5/8" ? Or is there some alternative fitting for the strainer? I'm sure some of you must have dealt with this.
Thanks!
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 01-28-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Thanks!
Nice title I would go with a barbed reduction fitting... its cleaner and works better than the old stretch it to the max routine....The other option you have is add a coupling that reduces the out put of the strainer to the desired width...(that allow you to stock only one kind of hose for a backup for the system) which is what I did for some of the re-work I did on my boat...either method works..
-- Jody
S/V "
1983, Barberis Show 38! or
Old 01-28-2008
Agreed, the strained connection is out. But what coupling is there for the hose-end metal fitting on the strainer? (sorry--don't know what to call it). All it has is a rounded lip to give a hose something to close around.
Tom
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 01-28-2008
artbyjody's Avatar
Tom
but is it on a nut so that it can be taken out and replaced with something other? A picture would be handy in this situation.... if all inclusive (meaning you can not attach or replace the fitting from the strainer)then you will need to do the barb convertor....
-- Jody
S/V "
Old 01-28-2008
Yeah, the strainer has a screw-in fitting--a 90 degree 3/4 NPT I believe. Sorry, working from a discouragingly non-photographic memory here. A similar picture of the strainer itself might be attached (if I got that right). So I guess I should look for a 3/4" NPT to 5/8" pipe fitting/adaptor, eh?
Tom
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 01-28-2008
artbyjody's Avatar
Tom
Would be my immediate suggestion less you want to split lines with the barb adapters etc... I like to keep system simple myself... so...
-- Jody
S/V "
Old 01-29-2008
It turns out it's hard to find a 3/4" NPT to 5/8" pipe fitting out there! I found just one, and it wasn't an elbow, just a stub. It might work for me but 2GM20 type Yanmars are pretty common with their 5/8" water intake, and apparently 3/4" NPT is the smallest size you see on Perko and Groco strainers. Others must have dealt with this.
So I'm curious what arrangement you all have in the strainer-to-intake-pump area?
Tom
arf145
1987 Pearson 28-2
Chesapeake Bay
Raw water strainer size?? Northeaster Gear & Maintenance 3 07-17-2007 09:41 PM
Perko Fresh Water Strainer # 493 puff6022 Gear & Maintenance 16 04-06-2007 06:37 PM
sea strainer location and plumbing? e31 Gear & Maintenance 2 10-01-2004 11:36 AM
Perkins 4-108 Oil Sump Strainer ABullard Gear & Maintenance 1 04-20-2004 01:00 PM
Sea Water Strainer joub Gear & Maintenance 2 01-19-2003 07:05 AM
