Blogs
User Name
Old 01-27-2008
poopdeckpappy's Avatar
poopdeckpappy poopdeckpappy is online now
Senor Frog
poopdeckpappy will become famous soon enoughpoopdeckpappy will become famous soon enough
Fresh water pump question
Right now I have a 3gpm PAR belt driven fresh water pump, I want to install a 4.5-5 gpm pump to reduce the pulsation and increase output from the showerhead, is there a side effect I should be aware of ??, all lines are in good shape
s/v Ivey League II
1978 Tayana 37
s/v Hale Kai
2006 Hunter 45CC
Old 01-27-2008
lharmon lharmon is offline
lharmon is on a distinguished road
Do you have an expansion tank in your system? If not adding one of these should get rid of the pulsing. The expansion tank has an air bladder and stores a quanity of water at your systems pressure and will reduce pump cycles and the pulsing. If you have an expansion tank the bladder inside it may be flooded or the tank needs pumped up with air. You can also make sure your showerhead is a reduced flow model.
Good luck,
Old 01-27-2008
Valiente Valiente is offline
Valiente will become famous soon enoughValiente will become famous soon enough
That's an excellent idea. If you are happy with the flow rate, the expansion tank is a better solution and is easily maintained. We have an expansion tank in our gas furnace/hot water radiator house heating system. Occasionally we get "water hammer" and we simply go to the highest rad in the house and bleed off trapped air which is giving the system a fit of the wobblies.
Here's a brief explanation of the principles. The tank needed for a boat's plumbing could be quite compact.
http://en.wikipedia.org/wiki/Expansion_tank
Old 01-27-2008
Freesail99's Avatar
Freesail99 Freesail99 is online now
Freesail99 will become famous soon enough
Expansion tanks are often installed to stop water hammer, said the plumber's son.
S/V Scheherazade
Tony Orlando stand in and Burt Reynold's stunt double.
Old 01-28-2008
bristol321 bristol321 is offline
bristol321 is on a distinguished road
there is also a "mini" sized (roughly 1" diam. by 4" tall) anti-hammer valve. We use them on every new job now per code. Available at any plumbing supply house.
Old 01-28-2008
christyleigh's Avatar
christyleigh christyleigh is offline
christyleigh is on a distinguished road
One thing that bit me in the wallet was my replacement of a struggling PAR belt driven pump was that I was un-aware of the Max PSI that my hot water heater pressure release valve was spec-ed for. I installed a Very High Pressure 51 PSI I think water pump last spring not knowing that my hot water heater said to only use up to 48 PSI. I didn't find that out until this fall reading up on my hot water heater to look at pressure valve replacement It worked fine for a while - although it was really too much pressure (splashing water in the sink) - then mid-summer the hot water heater pressure release valve started its own form of Hammering..... and I mean Hammering when the drain hose that was connected to it would jump around with the on and off release of pressure. Just last week I re- replaced it with a 40 PSI pump and I HOPE that when I reconnect the hot water heater in the spring that the relief valve will be happy
Probably a rare issue but it took me by surprize so it seemed worth mentioning
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Old 01-28-2008
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Sailor
JohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura about
Poopdeckpappy,
My gut feeling on this is that the higher pressure/volume pump will not solve the pulsing (might make it worse). Normally the problem you are having is addressed by adding the "expansion" tank mentioned above.
If you are having trouble locating an "expansion" tank, I thought I'd mention that in marine applications they are generally referred to as "accumulator" tanks. They are a fairly common component of domestic fresh water systems aboard sail and powerboats.
Old 01-28-2008
Sapperwhite's Avatar
Sapperwhite Sapperwhite is offline
Not So Senior Member
Sapperwhite has a spectacular aura aboutSapperwhite has a spectacular aura aboutSapperwhite has a spectacular aura about
PDP,
I have a Jabsco 1 litre accumulator tank on my fresh water system and have good steady pressure, and no pulsation at all. Install is easy, if you have 1/2" water hose. You just have to find a good spot on the high pressure side of the pump and cut the hose. The two cut ends go on the hose barbs and the third point of the "T" is the tank itself.
Defender looks to have the best price on it too, but you should shop around first.
http://www.defender.com/category.jsp...1271&id=316442
Here is a pic of the Jabsco 1quart, 1 litre, and 2 gallon accumulators
pumps/images/jabstank.jpg" border="0" alt="" />
Dictated, but not read.
Old 01-28-2008
Originally Posted by JohnRPollard View Post
Poopdeckpappy,
Just to be clear - my post about my high pressure pump wasn't meant as a cure for your pulsing or mine as I have an accumulator tank. My pump either needed rebuilding or replaceing and I chose replaceing. I just wanted to share my self-generated problem in case someone does need or wants to replace a pump with something other than the one that came with the boat.
Stan
'Christy Leigh'
NC 331
Old 01-28-2008
Sailor
Stan, I too should have been more clear. My response was in reply to the OP's statement "I want to install a 4.5-5 gpm pump to reduce the pulsation". I understood that your post was alerting him to a possible "side effect" of a higher pressure pump. Hopefully with our respective clarifications he'll understand what we were each getting at.
Display Modes
vB code is On
Fresh Water pump Gasket - dry or treated welshwind Gear & Maintenance 1 10-12-2007 05:46 AM
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 02:07 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
fresh water tank, tastes like ****! nauticalrich Gear & Maintenance 6 05-24-2002 04:17 PM
Pumps—An Overview SailNet Miscellaneous 0 12-31-2000 07:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
