02-01-2008
Great Lakes Sailor
Repair by trial (and occasional error)
I was in this position not too long ago, and finally just started working on parts of the boat I thought I couldn't damage beyond repair. It is amazing how easy much of the maintenance and repair work is on a small boat once you just try. I second SailingDog's suggestion for Don Casey's book, and there are a number of others out there that may help. Mainly you just need guidance on what steps to take, and then start out. What i have found is that what seems intimidating because I have no experience, often turns out to be relatively easy as long as you take it in small steps. Don't attempt to add or change thru-hulls as your first epoxy work, but smaller projects will give you confidence for the larger ones. Also, this site (and others) is great for quick advice if you get stuck in the middle of a project. Unlike magazines and books, there are a lot of sailors with years of practical experience that can give useful advice not found in books for that unique and puzzling situation you will find yourself stuck in from time to time. Good luck.
PDean
CS 34
Saginaw Bay, Michigan
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." - William Arthur Ward
