Transmission issues - SailNet Community
Blogs
Old 05-07-2002
jmlawrence is on a distinguished road
Transmission issues
I''ve acquired a 30ft Islander with a Palmer P60 and am having some transmission problems. Since I''m a neophyte sailboat owner with limited experience with the boat I''m looking for any and all tips. The main problem is getting in gear (forward and reverse) - you have to pretty much force it in gear. Unfortunately, I don''t really have the funds at the moment to have someone diagnosis it. I''m looking for any source of info in regards to adjustments or other things I could try...Thanks!
Old 05-07-2002
gnorbury is on a distinguished road
Transmission issues
You might want to start by disconnecting the linkage from the control arm on the gearbox so you can figure out where the binding is in the control linkage or the gearbox itself. (Mark the position before undoing the coupling!)
Graham
transmission question almostbroke Gear & Maintenance 8 06-05-2004 02:06 AM
Transmission Engages while in neutral...? kmeeks Gear & Maintenance 1 02-18-2004 10:56 AM
diesel - transmission, where is it???? nauticalrich Gear & Maintenance 2 11-01-2002 05:09 PM
Leaky transmission Volvo Penta 2003 ekhar Gear & Maintenance 0 08-15-2002 06:54 PM
Velvet Transmission manual AndrewB Gear & Maintenance 0 08-22-2001 09:05 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
