02-03-2008
Originally Posted by sailingfool
Assuming these winches share some design with the newer Ocean, remove the bearings and you should expose two plastic wedges set into the base that lock the spindle in. Slide the wedges out and you should be good to go.
If there are no wedges in the base, then another way to secure the spindle would be a split ring at the bottom of the spindle - turn the winch over and pry the split ring off.
No plastic wedges, but the ratchet gear assembly is removed by using a drift punch to remove the gear spindle. After that, the circlip on the bottom of the main spindle can be accessed. Clearly, the Ocean winches have gotten easier to maintain.
Since I see questions about these winches reappearing on these boards and elsewhere, I'll post pics of each stage and then again when I have the drums re-chromed
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
