02-03-2008
Originally Posted by sailboy21
Oh no! The first time I took down my mast I found an antique silver coin (1793). It was in fine shape, however it was sitting in a hole about 1/4" deep in places it had created in the cast aluminum mast step!!! I didn't want to bring bad luck on my vessel, so I replaced it with a silver coin of a little lesser value, but put in a little zip lock bag first
Back to the fuel tanks, but correct me if I am wrong that a metal tank in boat should never be in a position where it is constantly exposed/submerged in bilge water unless it is built in to the hull.
[Cam] - is your copper ground plate sheathed in Epoxy...? I was under the impression that is how it was done less it was a retrofitted deal?
[original poster]
As for the fuel tank - it really is dependent on the type of copper nickle (CuNi) ratio of the alloy used (its not a pure copper tank) as well as thickness. The oxidation is usually a protective barrier and unless not a proper ratio - usually will never cause a issue with the interior and the exterior can just be lightly scrubbed from time to time to freshen up the protective layer ...There is really no cause of alarm in most cases when dealing with copper tanks exposed in the bilge if proper maintenance is taken...
To give you more info on the subject I recommend reading:
http://www.copper.org/applications/c...er_topics.html
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
