Old 02-03-2008
trantor12020's Avatar
trantor12020 is on a distinguished road
What oil for Yanmar engine
I've a Yanmar 2GM20F. I uses EssoMobil Delvac MX 15W40 API CH-4, CF-4 ...-4, SJ/CF grade. My engine manual states only CD grade. Do I suppose the later/higher grade covers all older ones ? I checked on Torresen's web and they sells Yanmar brand oil (p/n: 41540) with the above API CH-4, CG-4, CF-4, CF/SJ grades for use with 2GM20F (I assume since it appears in the filter page for 2GM20F).
However, when I read my friend's 3YM30 manual, it states that the YM engine should NOT use oil with CH-4, CG-4,...-4 spec as this would cause excessive wear to the valve train assembly.
Now I'm uncertain if I should continue to use -4 spec oil for my 2GM20F for fear of same wearing on my engine. Any advise appreciated.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 02-03-2008
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
I use Chevron Delo in my 2GM.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 02-03-2008
theartfuldodger's Avatar
theartfuldodger is an unknown quantity at this point
Send a message via Skype™ to theartfuldodger
The 3ym engine meets the 2010 emissions, so reason for different oil and if you notice the injectors are on the other side another improvement for good burn, have a new yanmar in my morgan and real good on fuel.
The Artful Dodger II
NFLD and Labrador
33 Morgan O/I
Old 02-03-2008
I should also say that I'm a deisel mechanic, both heavy equipment and marine, love working on the yanmar its a real toy
NFLD and Labrador
33 Morgan O/I
Old 02-03-2008
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Doesn't Rotella T cover most of the Cx Sx additives? Isn't this oil one of the best available?
Old 02-03-2008
Yes is the oil of choice for sure
NFLD and Labrador
33 Morgan O/I
Old 02-03-2008
billangiep's Avatar
billangiep is on a distinguished road
I also use the Chevron Delo multi-grade in my 3GM. I was informed by the dealer not to use this oil in the trans. They sugested a straight 30 weight non detergent to reduce wear on the cone.
Bill,
Old 02-03-2008
dvpamenter is on a distinguished road
I use Rotella T in my 19822 GM. Diesel mechanic recommended.
Don
Clear Sailing
Alado agent - Canada
Old 02-03-2008
The 3gm uses a different oil then the 3ym, and yes the gear box takes a different oil then the engine, and depending on the slope of the engine, one has to be careful not to over fill gear box and cause foaming, which was something I learned the hard way but caused no damage.
NFLD and Labrador
33 Morgan O/I
Old 02-03-2008
k1vsk will become famous soon enough
These recurrent debates about lube oil seem to never end. This time I'll take the liberty of making the only important point to eventually result - that frequent changes of the oil and filter are FAR more important than what brand you choose as they are almost all essentially equivalent.
My New Catalina 25 42ndstreet General Discussion (sailing related) 23 09-06-2007 12:17 AM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 08:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
