Old 02-04-2008
camaraderie's Avatar
moderate?
WAY Cool New Battery Technology
Found this article by Nigel Calder through another forum and thought you would all be interested in a house bank that could be completely discharged...then charged at THREE to SIX Times its' amphour capacity in amps...and 100% charged in THIRTY MINUTES!!
Imagine a 100amp hour a day "budget" with a 500 AH bank. Tha means you could go 5 days without running your engine....then run it for a half hour and do it all over again!!
Best of all....this is NOT experimental...it is here now. The savings in fuel and engine wear should offsett the premium price very quickly...and the construction apparently has significantly longer cycle life as well. If you live on the hook or plan to...this is a real breakthrough...with more to come!
Read it here under "Breakthrough" in the table of contents. Click on the page to zoom in.
http://www.proboat-digital.com/proboat/20080203/
Old 02-04-2008
Valiente's Avatar
Excellent find, Cam. I will follow this us with more research.
Old 02-04-2008
moderate?
Val...check this out.
http://www.odysseybatteries.com/files/techbook.pdf
their "model 2250" battery is 1/2 the size of an 8D both in measurement and output. So 2 of the 2250 would fit in an 8d space. The tech specs are exciting but check out figure #7 in the link. This clearly shows that charging at 3x the rated amp hours gets you 100% in 30 minutes. Plus they are claiming 400 cycles from COMPLETELY discharged to 11.6Volts...500 cycles if you go only 80% discharged. This is the equivilent of 1000 cycles on a standard AGM or Flooded that can only go to 50% without shortening life cycle significantly.
Think about this:
With my 200 amp hour a day habit...I spent about 2 hours a day in charging mode on my 1000 amp hour bank...and spent about 2 gallons of fuel.
With these batteries I could stay off the grid for 5 days...spend 1/2 gallon of fuel with a DC generator...and also would reduce my ANNUAL engine hours from 730 to 36.5...and annual fuel use from 730 gallons to 36.5...saving rougly $2100 annually on fuel alone!!
The equivilent of an 8D costs $800...so that would be $3200 bucks for 1000amphours....so in about 18 months...the batteries would pay for themselves in fuel savings alone...to say nothing of reduced engine wear and maintenance and hundreds of extra cycles. At my use rate...they should last for 5.5 years of FULL discharges!!
It really changes the whole battery equation for full time cruisers. I wish was outfitting a boat right now!!
Old 02-04-2008
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
thanks cam, i've been looking hard at my pitiful little bank.
Dictated, but not read.
Old 02-04-2008
moderate?
Actually...I've been looking at the math...and while I COULD charge my bank in 30 minutes...I'd need a 44KW generator to do it! (3000 amps at 14.7 volts) so I guess I might be better off downsizing the bank size and saving some money and just charging a bit more often. Fun to play with the options since you can essentially also just buy half the battery amp hours you would otherwise need and go at it that way!
Old 02-04-2008
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
I looked at Odyessy batteries last year before I went with AGM's. Thought they were too new to the market to feel confident in them, in spite of their military use.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 02-04-2008
max-on's Avatar
1997 Dehler 33
max-on will become famous soon enough
Cam, you may find interesting the other 'cutting edge' things Nigel is doing to his new Malo 46, here is a link to his Blog: http://www.maloyachts.se/Default.aspx?tabid=195
There are a few articles in Professional Boatbuilder from Oct-Jan wherein he discusses things in more detail.
Old 02-04-2008
teshannon's Avatar
teshannon has a spectacular aura about teshannon has a spectacular aura about teshannon has a spectacular aura about
Smile
Think about this:
Hey, you could outfit the RV.
Old 02-04-2008
JohnRPollard's Avatar
Moderator
Cam, Thanks for the link to the article.
I had posted a link to the Odyssey webpage a couple months ago ( http://www.sailnet.com/forums/showth...dyssey+battery ) in the hope of eliciting comments from some of the folks who study battery technology. I'll be following this thread to see what the gurus think....
Old 02-04-2008
moderate?
Max...thanks for the link. I have some reading to do!
TE...don't think I haven't had that thought!!
JohnR...Yeah...I had looked at them over a year ago too...but just looked at their promotional sheets. Since they don't market to the marine market, the batteries simply looked like very rugged AGM's at exorbitant prices as the amp hours are nothing special and they don't get real specific about DEEP discharge, unique technology and "30 minute" charging. Only when I dug into the spec sheets download did I see what Calder was so excited about. The "guru" sure isn't resting on his laurels as he continues to explore the cutting edge of new tech!
Battery Bank Design Kevin Jeffrey Gear and Maintenance Articles 0 05-12-2003 08:00 PM
Battery Bank Design Kevin Jeffrey Cruising Articles 0 05-12-2003 08:00 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 08:00 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 07:00 PM
