02-04-2008
The electrical connections, like speaker and power connections can be pretty easily fixed using butt splice connectors, and they'll have marine grade ones at WM...but get the good ratcheting crimping tool at Home Depot instead, since it is 60% the cost of the same item at WM.
You should also be able to get some non-solder crimp on coax antenna connectors for the antenna cable, that are relatively simple to install, in case you need to change the end of the antenna cable.
