-   -   AM FM Antenna (http://www.sailnet.com/forums/gear-maintenance/40343-am-fm-antenna.html)
buddabelly 02-04-2008 05:50 PM
AM FM Antenna
Whats everybody using for there AM FM antenna? Can you "Y" into the VHF antenna at the top of the mast? I have looked around at the other boats in the marina and I don't see any antenna's other than the VHF..?
Pictures are always good too.
Thanks
Freesail99 02-04-2008 05:58 PM
A simple car antenna layed on top of the fuel tanks works great.
btrayfors 02-04-2008 06:03 PM
No, don't mess with your VHF antenna atop the mast.
Shakespeare and others make AM/FM antennas for boats. West Marine, Boat U.S., and other marine stores carry them.
Bill
sailingdog 02-04-2008 06:45 PM
Bad idea. The VHF would probably fry the stereo when transmitting. :) 25 watts of power straight into the back of your radio is a bad idea. Shakespeare and many other companies make smalll AM/FM/TV antenna. I have mine mounted in the cabin.
chef2sail 02-04-2008 09:30 PM
I use a Shakespeare small wire contained in a tape like covering with a plug in into the back of the AM/FM set which can be hidden from view and sells at West Marine. It gets good reception.
www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-[/url]
SHAKESPEARE ELECTRON
Antenna, AM/FM With Cable
Attaches to glass, so there is no whip to snag
This innovative design lets you locate an AM/FM antenna where it won’t get in the way. The On-Glass antenna is a clear tape with embedded antenna elements. The permanent adhesive strip can be attached quickly and easily to your windshield or any smooth, non-metallic surface. Includes a 6' cable and attached Motorola-type plug.
Application: AM/FM
Frequency: 550-1600 kHz, 88-108 MHz
Lead: 6' RG-62 cable, Motorola plug
artbyjody 02-04-2008 09:34 PM
That is not exactly a wise idea... a car antenna (which I use as well) just lays near a window... placing it on TOP of a fuel tank is bad as it introduces static and actual electrical charges, and if that is enough incentive not to do this - in case of lightening ... well I wouldn't want to predict what happens...
Gas tanks should never be used as grounding / reception bases period...
uspirate 02-04-2008 09:39 PM
cheap fix from Sailnet store and 50% off:)(click)
Freesail99 02-04-2008 09:40 PM
Seems to me of late, people are stating information as fact, when many of these ideas are off the top of someones head.
artbyjody 02-04-2008 09:40 PM
Sucking up are we :)
artbyjody 02-04-2008 09:45 PM
If you look at ABYC documentation, and other technical info publically available - I am not exactly making this up....(just assuming I owe thanks to you for my tagline and you think I am trying to be AFOC when actually am not)...:D:D
