02-06-2008
A bent swaged terminal is definitely a problem. If this is the kind of work the rigger has done, I'd highly recommend inspecting the lower end of the solent stay attachment at the deck. Is that properly backed and reinforced. Ideally, IMHO, a solent stay lower fitting should be tied into the hull and not just the deck, since it needs to transmit the load down through the deck to the hull itself, rather than relying on the strength of the hull-deck join to give it proper support.
