Blogs
User Name
Old 02-07-2008
maccauley123's Avatar
maccauley123 maccauley123 is offline
SailAway
maccauley123 is on a distinguished road
Wichard Gyb'easy?
I saw recently in a sail magazine an ad for a new device to help safely jibe. I used to do some climbing and it looks a lot like a figure 8 device used for rapelling. Campmor sells them for about 30 bucks.
The Wichard device sells for quite a bit and the only difference I see is it has the option of 3 settings. Why not use the climbing device? They are certainly strong and made for outdoor use.
I really like the idea and just think this may be a much more economical solution.
Thoughts?
Old 02-07-2008
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Moderator
JohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura about
Hi,
Some of us have been discussing the Gyb'Easy for a few days now. I seem to recall that some rock climbers chimed in as well:
http://www.sailnet.com/forums/showthread.php?t=40129
Old 02-07-2008
Freesail99's Avatar
Freesail99 Freesail99 is offline
Freesail99 will become famous soon enough
Originally Posted by JohnRPollard View Post
Hi,
Your to fast for me today.
S/V Scheherazade
Sponsored Ad
Old 02-07-2008
SailAway
Missed That
Missed that, guess I should have done a search first.
I looked through that post and it spends almost no time on whether a figure 8 would do the same thing. Did not seem to answer that question, went into jibe control in general.
Old 02-07-2008
teshannon's Avatar
teshannon teshannon is offline
teshannon has a spectacular aura aboutteshannon has a spectacular aura aboutteshannon has a spectacular aura about
Search under boom brake also and you'll see some additional posts.
Old 02-07-2008
Moderator
Yeah, I didn't mean to imply that your question wasn't valid, I simply wanted to make you aware of the other thread. I'm not familiar with the rock-climbers figure 8, so couldn't opine, but I'm curious. Maybe you could show us what it is and tell us how it works?
Old 02-07-2008
teshannon's Avatar
John,
I think someone posted a picture of one on the other GybEasy thread if I'm not mistaken.
Old 02-07-2008
SailAway
Figure 8
Sorry, John, did not mean anything, just noting it did not really go into it much. I should have looked to see if this had come up before.
The idea behind the figure 8 is the same as the Wichard device. Shaped like the number 8 with the lower circle larger. You pass a doubled over rope through the larger hole then up and over the top circle. It snakes around the device then with friction.
Just like the Wichard device you can clip the top to the boom then each end down the the sides of the boat. Run at least one end back to the cockpit so you can increase or decrease the tension. Decrease the tension when tacking and increase when jibing.
I would post a picture but I am a new user of the forums and don't have enough posts yet.
Old 02-07-2008
sailingdog sailingdog is offline
sailingdog is just really nicesailingdog is just really nicesailingdog is just really nicesailingdog is just really nice
Unfortunately, the figure-eight rappelling carabiner isn't going to provide enough friction on most boats. That's why the Gyb'easy has additional holes in it for the line to pass through, to create more surface contact and more friction. Personally, from what I've seen of the three major boom brakes, I think the Dutchman Boom Brake is the best over all, since it is far more adjustable than the Gyb'easy and far less expensive than the Scott Boomlock.
If you're new to the Sailnet Forums... please read this POST.
Old 02-07-2008
soulesailor's Avatar
soulesailor soulesailor is offline
blue collar cruiser
soulesailor is on a distinguished road
I don't see any reason why you couldn't give the figure 8 a try. The set-up on the side decks and cockpit area is the same as with any boom brake. The only difference is the actual piece of gear the line runs through hanging off the boom. If the figure 8 performs unsatisfactorily just replace it with a proper boom brake piece and possibly with a new line (I think that wichard one suggests a specific line) and you're running again. I have a feeling the figure 8 will be a bit slippery and not slow the boom down as much as a real boom brake. Since I already own a figure 8 this is exactly the plan I intend on following when my boat hits the water in...late May????.....oh my god! So long from now!!!
who is staring at the sea is already sailing a little
vB code is On
Opinion on Wichard Quick Release Shackle? labatt Gear & Maintenance 3 07-16-2007 01:25 PM
Why is rust forming?? jr438234606 Gear & Maintenance 6 07-28-2006 08:39 AM
Page generated in 2.0492 seconds (90.08% PHP - 9.92% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
