Old Roller Furler (a.k.a. "To Furl, or Not To Furl...") - Page 4 - SailNet Community
post #31 of 35 Old 02-08-2008
Maine Sail's Avatar
Originally Posted by T34C View Post
Plump- Ok now I understand what you are getting at. I don't agree, but understand what you are saying. I've never heard any accounts of boats that were even so much as knocked down because they had a furled headsail still on in heavy weather.
T34,
I have been lucky or unlucky enough to have been knocked down a few times over the years. Not fun! Each time I was knocked down I was on boats with head sails rolled up or just a sliver of it out for balancing the helm in heavy winds and seas.
Each and every time was the result of falling off a wave or bottoming out in the trough and then having the wave knock us down. While the wind can do it, if over canvased, it was not the power of the wind or the windage knocking us flat or to the spreaders. In fact I've never been under bare poles and had the wind knock the boat down even on boats with mast mounted radars and dual head sails on furlers.
In every severe weather knockdown I've encountered the boats popped right back up within 15 seconds or less even with all the weight aloft of wet furled sails and a furler.
Contrast that with bay broaches/knockdowns I've encountered, in flat conditions but high wind under spinnaker, with tender racing boats and even with a big wet chute draped in the water these racing boats still pop back up no problem...
Again the OP should try the furler first before dumping it. Besides dumping it will most likely require a new head stay and a sail conversion to hanks $$..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #32 of 35 Old 02-09-2008
Wish I never found SN!
SimonV's Avatar
Furler’s are here to stay. They have proven to be reliable and work for racing and cruising. If buying a second hand boat without a furling headsail, I would adjust my offer, to allow for the purchas of a furler unit and new sail. I don't think I am alone on this.
As to Cam's comments he should know....HE'S GOT FOUR (4) OF THEM.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #33 of 35 Old 02-09-2008
Sailor
Plumper's Avatar
There is a direct link between this thread and the "Sensible Cruising" thread. I just wouldn't spend the money to change the boat one way or the other if everything was working fine. I'd just go sailing.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Plumper is offline
post #34 of 35 Old 02-09-2008
Originally Posted by Catalina274me View Post
It's like going from a stick shift car to an automatic.
Oh Geeze, here I thought going from Automatic to a Stick shift was the way to go!
Course it helps if you're driving THIS....
sailordave is offline
post #35 of 35 Old 12-24-2008
Furled sails do suffer from a compromised shape. Furlex and Harken have "one free turn" on drum to help combat this, also a foam or similar aeroluff can help. Nonetheless most of the trouble I've seen with furler operation were due to:
1)improper installation leading to halyard wrap
2)improper use leading to halyard wrap (they're not goof proof)
3)just plain old and worn out
4)lousy product, not so common anymore
5)lack of maintenance
6)wrong size, put together wrong, forestay to slack
captainmidnight is offline
Roller Furling Lay Up Tom Wood Gear and Maintenance Articles 0 10-21-2003 09:00 PM
Installing Roller Furling Sue & Larry Gear and Maintenance Articles 0 08-09-2002 09:00 PM
