Old 02-07-2008
travistowle's Avatar
Topeka, Kansas 66604
travistowle is on a distinguished road
Send a message via Yahoo to travistowle
Question Keel Stepped Mast corrosion question.
Hi guys, while I am not new to boating I am new to this size of yachts. I grew up sailing C-Scows and now I want something bigger that I can sail around the USA. I am looking at the following:
A 43' Gulfstar Center Cockpit Ketch.
Looking over this yacht I thought I better post a question about this mast base. I have added a picture link of the problem base. First can this mast be fixed? If so how?
Also, I am having problems finding a mast supplier that can give me an “about price range” for both a replacement aluminum mast and carbon fiber – any ideas?
Is there a place that you can find USED replacement aluminum and carbon fiber masts?
Travis E. Towle
Topeka, Kansas
785-357-1004
Old 02-07-2008
camaraderie's Avatar
moderate?
I think any good yard could restore that mast for you. Probably need to cut of f corroded end and fabricate a sleeve for the bottom of the mast. Probably would be advisable to prep and 2-part paint the mast before re-installing.
Old 02-07-2008
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
I agree with Cam that the mast can be fixed. Also, does the mast sit on some sort of a step in the bilge? It it's a metal step, check that for corrosion as well. you may want to think about building up the step to keep the mast base up higher out of the bilge water. There are any number of ways to do that.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
Old 02-08-2008
TassieBloke's Avatar
TassieBloke is on a distinguished road
I dont think the mast is the only thing that needs repair. The outboard in the background looks like it needs a few hours spent on it as well.
Old 02-08-2008
You could also cut off a few inches off of the bottom of the mast and raise the mast step by the same amount. This is a pretty standard way of dealing with such corrosion of the mast... and doesn't require you to re-rig the boat at all. It is often easier and less expensive than re-building the mast step, and can often be a stronger repair.
Old 02-08-2008
dfreer is on a distinguished road
If you are looking for a new mast - check with Seco South in Largo, FL. They will give you prices and I have found them the best priced around.
Old 02-19-2008
Thanks for your input on this guys, I will pass on this yacht as this is only a start of the problems it has!
Travis E. Towle
Topeka, Kansas
Old 08-21-2008
pearson301 is on a distinguished road
Replace corroded mast step
I am finally taking care of a long neglected item on my Pearson 303. The mast step and bottom edge of the mast are corroded. The yard wants to cut a couple of inches of the mast and install new step on top of a fiberglassed wood block to make up the difference. Seems reasonable to me, but I recall from years ago when I was active on this list, there was a company that one could send the cut off portion of the mast to, and they would manufacture a new step, I believe out of delrin, that would make up the difference.
Anybody familiar with a company that could do it? Any other suggestions?
thanks for any input,
Peter Lindeman
P 303, Blue Chip
Charleston
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 17 09-17-2008 04:54 PM
Southern Cross 31? db27513 Boat Review and Purchase Forum 35 09-24-2007 10:58 PM
deck or keel stepped xort Cruising & Liveaboard Forum 14 05-23-2007 11:29 PM
Wing vs Fin Keel pixurman General Discussion (sailing related) 10 05-28-2004 04:01 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
