02-07-2008
We have some lines on our boat that would seem to date from 1981, when she was built. She's been raced fairly heavily throughout her career, so we have replace some lines like halyards and some sheets that get worn or chafed. Others, like those reeved inside the boom, don't get damaged as much by UV rays, and don't wear much. For example, the outhaul, once it's set, doesn't get adjusted much. No need to change it. Some original lines may have been oversized so as to "feel" better to hand, and so are still plenty strong enough. They haven't worn out, so we keep using them. We've also had the kevlar jib halyard part a couple of times under load, so it's time for a new one of those. We think that one is about 20 years old, and the line takes a high-load tight radius turn over the masthead sheave, which is something kevlar does not like. The point is that there is no reason to replace all the lines on board, wholesale. Fix the ones that need fixing, as they need it. In the interim, spend money on better wine and you'll enjoy your boat more.
