Cockpit drains - Page 3 - SailNet Community
post #21 of 41 Old 02-12-2008
Midwest Puddle Pirate
US27inKS's Avatar
Originally Posted by Hartley18 View Post
I understand your first 2 sentences, but not the third.. You're saying that the leeward scupper would drain out the high-side through-hull?
That would be the first time I've heard anyone say water flows uphill..
No, not uphill at all. If you have a look at some crossed drains such as mine, http://groups.msn.com/baylinerbuccan...o&PhotoID=2193 You'll see that the boat would have to be heeled at 45 degrees or more for the drain hoses to be level. Even with a level hose, the hydraulic pressure of the water level being higher than the through hull would continue to push water out, but slower. The through hull fitting would have to be higher than the scupper for the drain to not work at all, and at that point the cockpit would be self draining (over the side).
US27inKS is offline
post #22 of 41 Old 02-12-2008
Once known as Hartley18
Classic30's Avatar
Dock
Originally Posted by US27inKS View Post
No, not at all. If you have a look at some crossed drains such as mine, http://groups.msn.com/baylinerbuccan...o&PhotoID=2193 You'll see that the boat would have to be heeled at 45 degrees or more for the drain hoses to be level. Even with a level hose, the hydraulic pressure of the water level being higher than the through hull would continue to push water out, but slower. The through hull fitting would have to be higher than the scupper for the drain to not work at all, and at that point the cockpit would be self draining (over the side).
That makes sense - interesting photo!
I'm used to wide, low cockpits with drains connected together and led out the back to empty the cockpit quickly You learn something new every day on Sailnet!
Classic30 is offline
post #23 of 41 Old 02-12-2008
US27inKS's Avatar
It does seem that boats with a narrow transom like mine are more likely to have crossed drains.
I took that pic the day I bought my boat. It was more for a record of what it looked like for reassembly than anything. In the foreground is the empty Volvo saildrive mount. Now I have to mess with my stupid outboard. It's a PITA, and it spoils the lines of the boat.
US27inKS is offline
post #24 of 41 Old 02-12-2008
moderate?
camaraderie's Avatar
Yep...crossed wouldn't work on mine...depends on the boat and the location of the through hulls...mine are both below the waterline.
camaraderie is offline
post #25 of 41 Old 02-12-2008 Thread Starter
Molded floor for drain
Cam,
Here's a pic of the floor in the cockpit area. With the floor molded like this it's pretty hard to get the right fitting. I still think that the "I" fitting will work if it not to big or tall. Remember I took out a standard lavatory tail pc. so it fits perfect in the lower area which catches the water. The screen plate just layed over it with a couple of screws holding it in place. I really wonder what was installed originally. Any thoughts?
gg30citation is offline
post #26 of 41 Old 02-12-2008
sailboy21's Avatar
Originally Posted by gg30citation View Post
Cam,
Probably what you took out!
Would a flush head thruhull fitting fit? If not, maybe you could get one turned down a little on a lathe.
sailboy21 is offline
post #27 of 41 Old 02-12-2008
moderate?
I think you just need to find another small plastic piece to go back in there. Anything else is gonna require a bunch of glass work. What is the dimension on the outside of the lip of the lower hole?
post #28 of 41 Old 02-19-2008 Thread Starter
Cockpit drain supplier
Hey All,
Update on the search for a replacement cockpit drains for the Irwin. Turns out Marineeast.com has a line of drains that will fit in the recessed area of the molded cockpit floor. The drain fitting has a 2" flange and 1-1/4 dia. body with locknut. the lower body is barbed for a hose.
gg30citation
post #29 of 41 Old 02-19-2008
moderate?
glad it worked out gg.
post #30 of 41 Old 02-27-2008 Thread Starter
Opinion!
Help again everyone,
These cockpit drain are something else! What would you guys do? I'll let the pics do the talking for me. And just maybe someone that has a 30' Citation will look and see what's installed on there's. Please Help! Cam: I'm not sure what to do! the plastic thru-hull sticks up alittle to high and the hole is smaller, I just might have to use the lav. tail pc.
gg30citation
Cockpit drains 011A.jpg   Cockpit drains 013A.jpg   Cockpit drains 015A.jpg   Cockpit drains 016A.jpg   Cockpit drains 017A.jpg
Cockpit Drains KeelHaulin Gear & Maintenance 4 01-15-2008 01:35 PM
The Cruising Cockpit Sue & Larry Buying a Boat Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Gear and Maintenance Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Cruising Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Her Sailnet Articles 0 07-08-2003 08:00 PM
