Old 02-11-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
What is a barrier coat?
I don't want to open a can of worms here.. but I am a little confused and have a few questions:
1) Does the gelcoat on the hull have to be removed to apply a barrier coat?
2) How thick is the coat going to be? Will it require hull fairing?
3) If it can be applied over gelcoat, what is the best way to get rid of all the old bottom paint?
Forgive me.. fortunately haven't spent much time on the hard
Old 02-11-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Gelcoat is extremely porous actually.... a barrier coat is used below the waterline to seal the gelcoat before applying other ablatives...Typically if done properly - no fairing is needed but you need to apply several coats to get a good seal...before applying all else...So yes it is to be applied over gelcoat that has been sanded ...
-- Jody
S/V "
1983, Barberis Show 38! or
Old 02-11-2008
Maine Sail's Avatar
A) No but it must be dry and properly sanded and de-waxed
A) Anywhere between four to seven coats. Any fairing should be done before you apply a barrier coat.
A) I prefer scraping but sanding, soda blasting and chemical strippers can also be used.
Interlux 2000E in alternating coats of white and gray woks great to ensure good coverage.
My answers are in the quote in red..
______
-Maine Sail / CS-36T
Old 02-11-2008
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
Halekai gave good answers. Here's a site with more info. I used MAS epoxy when I barrier coated my boat and have been quite pleased with the result.
http://www.masepoxies.com/public/ind...iontype=How-To
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
Old 02-12-2008
ronbo1 is on a distinguished road
At the risk of opening that-can-of-worms Sailboy, there are pros who say that Interlux barrier coat is minimally effective. Better to use vinylester or epoxy resin. Anyone else heard this?
Ronbo
Old 02-12-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
I personally would like to see some facts stating that epoxy paint is anywhere as good as a barrier coat as epoxy resin. Having removed both, the paint comes off by far easier then the resin.
S/V Scheherazade
Old 02-12-2008
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
I might note that Sailboy makes no mention of actually needing a barrier coat on his boat.
It's my understanding that one generally applies a barrier coat to a vessel with either a history of osmotic blistering, or a brand name and age of vessel known for a propensity to blister. Probably most boats merely require a well maintained bottom paint.
Wm. F. Buckley, Jr.
Old 02-12-2008
sailboy21's Avatar
Indeed I do not need a barrier coat.. however
I am considering a haul out to replace all of my thruhulls and the poor old girl has at least 4 bottom jobs worth of sand & paint style ablative application. The bottom needs to be stripped down completely. I've also bumped a couple of very sturdy submerged objects, and since I have an encapsulated keel I figure it couldn't hurt to barrier coat the whole thing. If I haul out and start dropping the $1,000's I may as well not stop until either my CC's are maxed out or the bottom is done right! It has probably been 12 years since it was a complete bottom job was done.
Old 02-12-2008
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
When buying my Nauticat, my surveyor - through exploratory and random scraping - uncovered several pinhead sized osmotic blisters, scattered throughout the bottom. Although very tiny, he recommended repair.
I received an estimate for the work through the seller's boatyard and used this number to renegotiate the selling price - subsequently hiring them to do the work.
Throughout the upcoming winter, the masts were unstepped and the boat was hauled into a heated paint shed. Starting with removal of all bottom paint with Peel-away, a crew grinded out all the blisters. The hull was then tented with plastic sheeting, taped above the boot stripe and secured to the concrete slab, which was radiant heated.
After allowing the hull to dry out for several weeks, until acceptable moisture meter readings were reached, the hull was then faired smooth with many gallons of fairing compound. Interlux Interprotect 3000. an epoxy barrier coat, was then sprayed on in several coats, exceeding mfr recommendations. The finished surface, smooth as new gel coat, was then prepped to receive my application of three coats of bottom paint.
Upon the recent inspection of the hull by the new owner's surveyor - four years later, the surveyor praised my decision to do this work, stating it added immensely to the boat's value.
True Blue . . .
sold the Nauticat
Old 02-12-2008
billangiep's Avatar
billangiep is on a distinguished road
sailboy, This might be of interest,explains the how and why's..pdf file.
http://www.yachtpaint.com/USA/hotlin...t_bulletin.pdf
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 09:18 AM
Vinylester Resin - Barrier Coat craigtoo Gear & Maintenance 26 02-02-2008 09:01 PM
Barrier Coat - Amerlock 400 by Ameron ? dougshipl Gear & Maintenance 5 12-31-2007 01:10 AM
Is Vinyl Antifoul better over Epoxy Barrier Coat pds Gear & Maintenance 3 08-27-2001 12:27 PM
Barrier Coat stupidgringo Gear & Maintenance 0 08-23-2001 04:53 PM
