Force 10 Diesel Cabin Heater - Page 2 - SailNet Community
 1Likes
post #11 of 23 Old 02-14-2008
Rear Admiral
Originally Posted by KeelHaulin View Post
I am running 60% Bio-Diesel; so it sounds like any combo of bio will work on the heater also?
It should indeed. Right now we mix about 10% petroleum diesel in our heater tank, but i see no reason why b100 wouldn't work as well.
Is it OK to use algae preventer in the fuel that goes into the heater? If it is I will plumb a line from the exit of the Racor filter over to the heater's tank. That way I can refill without any fuel spillage and keep the tank in a location that is not near the heater.
I can't see any reason why not. I don't use anything of the sort really, but i only carry about 40lt of fuel in the main tank, and i've never had a problem with algae.
It sounds like I will need to install a guard around the exhaust pipe to prevent hands from getting burned on it.
That's a good idea... on my list of things to do. I've leaned on it once or twice and was quite unhappy afterwards .
How do you control the flow of fuel to the heater? There is a small hex fitting beneath the burner; is that the needle valve or do you need a needle valve in-line from the tank?
My force10 has a little regulator unit where the fuel comes in. It's got a knob with the hex nut in the middle. The hex nut is used to adjust the fuel/air mixture, and the knob the flow of fuel. If your unit does not come with this little device, i beleive you can buy them aftermarket, and i recommend it.
When you de-pressurize the tank you just bleed it from the tank valve? How do you vent the vapours and is this an explosion concern if there is a source of flame? I don't like the idea of venting it to the cabin when I shut it down; but the instructions on the tank say to release the pressure when not in use. Do you do this?
I don't have a pressure tank really, so i can't give you any good advice here. I try to keep all the pressure out of the system (i'd rather have it stove go out than not go out), and every couple uses i open the tank to equalize the pressure that has built up.
I wouldn't worry too much about the diesel fumes, because again they are not really all that flammable when things are cool. That said, i don't like the idea of venting into the cabin either... but i do think the system should be vented after use.. my stove was lit (i had thought it out, and turned off the regulator) for a week once without my knowing as the pressure was high... i was not on the boat. That could have been an expensive lesson.
drewc is offline
post #12 of 23 Old 02-15-2008 Thread Starter
STARBOARD!!
KeelHaulin's Avatar
Great... I think I have enough information to set it up and test it. I decided to remove the burner element from the heater/boat. I can set it up at my workbench and make sure it is operating properly before I install it on the boat. It will be easier to put out if there is a flare up or I acidentally set fire to something etc.
Looks like everything could use a good cleaning and the knob for flow that you mention is not there; must have been broken off. The stem is a little bent from whatever broke the knob but it will turn if I use a pair of pliers. I will have to find a replacement for the knob. The stem only turns about 90deg; is that correct or is it sticking?
KeelHaulin is offline
post #13 of 23 Old 02-15-2008
Rear Admiral
Mine will turn through 360deg, but i've seen a few different regulator models so this may not be indicative of something being broken.
drewc is offline
post #14 of 23 Old 03-13-2008
Break, curse, fix, repeat
bwindrope's Avatar
Biodiesel doesn't work
I'm sorry if I didn't read every word but I think this thread is getting onto the subject of burning biodiesel in a Force 10. I have a Force 10 diesel heater just like the one in question. I have had to become an expert in its repair and maintenance. I am profoundly bummed that they are no longer manufactured and you can't get parts anymore really. I've been told that by Fisheries Supply here in Seattle.
Anyway, my heater works absolutely great! I have a digital CO detector onboard and it never budges above a reading of "0". My alcohol stove causes condensation and CO to raise a little, but not the heater.
Anyway, I burn biodiesel in my Universal M40, about a 75% mixture give or take. I tried to burn B99 in my Force 10 and let me tell you, definitively, it does not work. I primed the hell out of it, with several cup fulls of alcohol, and the biodiesel just does not get hot enough to not smoke like crazy. Let me tell you, I filled my cabin with smoke several times trying to get biodiesel to work. Then I tried B20 and it was better but still smoky and obnoxious. Finally, I bought good stove Kerosene, and she burns clean, clear, and hot. No soot, no smoke, and no problems.
I don't have, or want, propane on my boat (Boom), and so hope to keep this stove going for a long time.
My two cents.
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
post #15 of 23 Old 03-14-2008
artbyjody's Avatar
BW: good info on the attempting to use bio for heating.... I always thought it would may be doable but in engines they operate under higher pressure and temp than one of those stoves - so had my doubts... thanks for the input....
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #16 of 23 Old 03-14-2008 Thread Starter
STARBOARD!!
KeelHaulin's Avatar
Thanks... It sounds like kerosene is the way to go since my diesel is appx 66% biodiesel. That changes everything in terms of how I will plumb/fill the pressure tank.
post #17 of 23 Old 03-14-2008
bwindrope's Avatar
Sure wish Biodiesel worked, but...
Yeah, I'm sure we all share the same desire for biodiesel to work and I sure wish it did. For mechanical and environmental and political reasons, I run biodiesel in Aeolus and own a wonderful 1978 Mercedes 300D with a cast iron engine and run B99 in her. I gave the biodiesel a good long try on Aeolus and just had to conclude it doesn't work. I even disassembled everything and made sure the fuel port was clean and all that. Even straight dino diesel doesn't work nearly as well as Kerosene as far as a clean burn. I wish it weren't so...
Someone had mentioned that they thought the Force 10 did not heat very well. They may be right relative to other units, but although I'm no expert, not having owned one of the new propane units, I have been very happy with the heat output of my Force 10. Our 32 foot pilothouse is pretty roomy inside, and she warms right up to a comfortable take-off-the-fleece temperature even here in our damp 38 degree temperatures.
We have a nice little fan mounted above the unit on the bulkhead and then really spreads the heat out well.
Hallelujah for the end of winter...and arrival of spring!
Aeolus
Gulf 32
post #18 of 23 Old 10-21-2008
Force 10 Diesel Heater
Hi there,i have a Force 10 diesel heater installed on my Fisher 25 "Cathy.B" and i use a good grade of diesel,and i have never had any problems due to me using the higher grade.my heater is fed from a pressurized tank (connected to the burner assembly via 1/4" copper pipe ) which feeds a constant pressure which i usually pump up to between 10 and 20 psi or 3/4 to 1 1/2 atm at this pressure it provides a nice size of flame.the secret to getting the heater to work properly is to make sure the burner is pre-heated up i use methylated spirit,once heated up sufficiently the control knob is opened up and the diesel enters the pre heated burner assembly the diesel actually turns from its liquid form into a gas form and produces a nice blue flame"as if it were burning propane, I do have an owners manual for the heater and would easely oblige you with a copy if you were to give me an e-mail address
ALEXBIR is offline
post #19 of 23 Old 10-21-2008
Moderator
JohnRPollard's Avatar
KH,
I somehow missed this thread way back when you posted it.
Sorry if this has been mentioned, but I just thought I'd relay my understanding that the Force 10 cabin heaters were picked-up by Sigma Marine, in case you could obtain some info from them:
Welcome to SigMarine.com - Marine Heaters & Stoves - Our Product Line
EDIT: Oops never mind, Art got the info to you already...
JohnRPollard is offline
post #20 of 23 Old 01-12-2009
Hello everyone!
I have a Force 10 desiel heater that I have been trying to get to work, but I think that I am missing the inner cap. The pressurized stream just shoots straight up in to the heater body cuasing horrible soot and flames.
Does any one have a picture and demensions of the inte inner burner cap? And pictures of the burner. Thanks for the help.
Kirk in Annapolis
kfistick is offline
Diesel Heater Carboning SV_WholeHeart Living Aboard 8 10-27-2011 07:43 PM
Force 10 cozy heater flydude3 Gear & Maintenance 2 01-10-2010 11:11 PM
Propane Cabin Heater Mysun Gear & Maintenance 9 06-07-2009 11:29 PM
installing duct system for diesel heater and air conditioner levenezia Gear & Maintenance 1 09-25-2004 03:20 AM
Force 10 Cabin Heater quinlanmw Gear & Maintenance 11 12-27-2003 05:25 PM
