Crimping versus Soldering - Page 17 - SailNet Community
Blogs
  #161 (permalink)
Old 05-28-2009
The fact that you've had to go back to the Apollo missions says much about NASA and the reliability of crimping electrical connections. I'd tend to think that equipment and technology have improved a bit since the Apollo missions...
  #162 (permalink)
Old 05-28-2009
Maine Sail's Avatar
Originally Posted by eolon View Post
Copper is very soft and ductile so cutting through a crimped connection smears the metal and indeed makes it look like a "solid mass" of metal. A proper metallurgical inspection of a crimped connection involves slicing a section of the crimp with a microtome and looking at the surface with SEM. The interstitial spaces are always present, and can be very small, on the order of angstroms, but no amount of force can fuse copper wires into a solid mass. Unless you melt it, which I wouldn't recommend.
This is why I polished it to remove any smear. If there were enough room for water to get in you would see black dots from the very soft tripoli polising rouge stuck to the surface. Lets not forget that your spar is held up by a similar concept called swaging where the metal is compressed into a near solid mass. Perhaps we should all weld/solder our swages??
Also what is the size of a molecule of silver as in silver solder? Is it smaller or bigger than an angstrom? Considering that every reference I have seen states that crimps must be applied BEFORE solder how is it that the solder can penetrate an angstrom??
  • One angstrom unit (A.O. or Ĺ)= 0.1 nanometers, or one ten-thousandth of a micron (10-4 microns), or one hundred-millionth of a centimeter (1 x 10-8 cm.) One angstrom is the diameter of a hydrogen atom -- the smallest element.
If hydrogen is the smallest element how large is silver? Would it do any good to add solder to a properly crimped battery lug if it can't penetrate?
Apparently you missed the part about the NASA requirement that the crimping of pre tinned wire is BANNED. Mil Spec also states teh same. As usual the 30 year veteran electrical engineer knows more than anyone else or the collective wisdome of the entire aerospace industry or the ABYC which is made up of people/voting members, in the industry, including electricians who work on boats every single day.
I also thought that a water molecule was nearly three times the size of an angstrom making it physically impossible for water to penetrate through a proper crimp.
This is a poor crimp made with a cheap tool & cut open with the same tool. You can see wires because this is a crappy connection. Like with soldering the right tool and the right method MUST be used only it is MUCH easier for a novice DIY to make a good connection with the proper crimping tools than it is for them to do the asme with solder, hence the current ABYC standards..
Crimping is a great mechanical connection, and a servicable electrical connection.
Yep and plenty servicible for NASA, the aerospace industry, US Army, Marines, Air Force & USCG, Ford, Honda, Toyota, GE and thousands of other companies who rely on billions of crimps world wide every day..
Solder, especially modern, lead-free solders, are also very soft, and better yet, not prone to embrittlement.
Really so how many 30 degree bend cycles will a tinned section of 14 ga marine wire handle with and without solder? I know the answer becuase I have tested and done it before. The non tinned wire will handle considerably more than 1000% more 30 degree bend cycles than the same wire tinned..
A proper solder joint fills interstitial spaces, and a proper crimped connector will deform the soldered wire and make an excellent connection.
Keep telling your self that crimping after tinning is a good idea and soon enough you might even believe yourself..
I sometimes use solder joints and sometimes crimped connectors, and sometimes both.
I am simply putting in my 2cents worth of 30 years of electrical engineering, take it or leave it, as usual.
Everyone can do as they wish on their own boat as you do. Is your 30 years of EE in the marine industry?? Sometimes applying theories learned in one industry does not always pan out in another.
Take for example the many mechanical and aeronautical engineers who have been proven wrong about propeller drag. For yeas they would pontificate on helicopter blade analogies and and use "lift" arguments and in geneneral be adamant that a locked prop caused more drag. It apparently does on a helicopter but does not not when dragged through the water at 4-6 knots attached to a boat...
Oh, and how about the electrical failure that roasted 3 astronauts in the Apollo project?
How bout it? It was not caused by a solder vs. crimp situation and as suggested by the NASA investigation could have been caused by perforated teflon wire insulation. This is why you need to support wires and have proper strain relief. This was more likley chafe than a connection issue unless of course you are trying to re-write NASA investigation history..
Originally Posted by NASA
4. CAUSE OF THE APOLLO 204 FIRE
The fire in Apollo 204 was most probably brought about by some minor malfunction or failure of equipment or wire insulation. This failure, which most likely will never be positively identified, initiated a sequence of events that culminated in the conflagration.
...just because all the other kids jump off the Empire State Building doesn't mean I'm going to.
Best Regards,
e
By all means it's your boat and you should do as you wish.
You need to understand that some of us have actually worked in the industry and have seen lots of solder failures, incorrectly or correctly done, it does not matter because we know the vast majority of boater CAN NOT do it correctly. No one is disputing that solder makes an excellent electrical connection, it does, but the application is the tough part.
The many, many, many voting members, of ABYC, of which one is a friend, have also seen these solder failures. There is a reason the industry suggests crimping over soldering. Just yesterday I asked the electrician at the boat yard what are his two most common electrical failures. Answer #1: Corrosion & Answer #2: Soldered joints. I also asked about crimps and he said occasionally he will see a bad one but that it was poorly done to begin with. I also aksed if he has ever seen a failure of a heat shrink crimp connection and he said yes. He then went on to describe this failure as one that a boat owner decided to hang a winch handle from in a lazarette and the ring part of the terminal broke from the swinging handle after two seasons of this. He then laughed and said .... "A real failure? No.".....
You need to know that when you make blanket statements that you will be debated so that those reading this forum can make their own educated decisions. Just because you have 30 years experience as an EE does not mean you are always right and there are many other variables that one can and should consider.
______
-Maine Sail / CS-36T
  #163 (permalink)
Old 05-28-2009
wind_magic has a spectacular aura about wind_magic has a spectacular aura about wind_magic has a spectacular aura about
Maine sail, that was all very interesting, I learned a lot by reading it. You even answered the question I had in mind when you showed what the badly crimped connection looked like when you cut it open - thank you for going the extra mile, it was like watching myth busters.
Question - Did you say above whether it was a good idea to solder after you made a good crimp or to leave the good crimp alone ? I have been doing crimps and then soldering, what is your opinion on that ?
One odd thing you showed me was that the bad crimp wasn't as bad as I thought it would be inside, I actually imagined worse.
What are you pretending not to know ?
  #164 (permalink)
Old 05-28-2009
Maine Sail's Avatar
Soldering after a crimp has been made is fine provided you:
A) Know what you are doing (most don't).
B) Use a heat sink to prevent solder creep up the wire
C) Use the correct solder.
D) Use proper strain relief/adhesive lined heat shrink.
E) Use the proper crimp terminals for soldering which are different and non-insulated and rarely as robustly built as the insulated ones or heat shrink ones.
F) Use the proper crimp tool for the solder/crimp terminals which most don't own or have if they have been using a crimper designed for insulated crimps.
In short doing crimp then solder requires different tools, proper training and more labor and will not really yield any better end result.
The bottom line is that there are billions of crimps in use world wide maybe even trillions. Yes solder makes a great electrical connection but is very tough to do correctly, is brittle at the solder wire junction and if resistance becomes an issue it can melt leaving a dangerous hot wire dangling. This is why ABYC recommends a mechanical connection first then solder if you feel the need.
IMHO the best bet is to buy adhesive lined heat shrink crimp terminals and the proper single crimp ratchet tool.
Sailors Solutions sells the heat shrink crimps and the crimp tool. I don't see any need to crimp then solder when using proper connectors w/adhesive heat shrink and the proper crimp tool.
______
  #165 (permalink)
Old 05-28-2009
Maine Sail's Avatar
Originally Posted by jackdale View Post
Nigel Calder recommends soldering.
I have had to backtrack on this one.
Jack,
Let's be clear and please quote us the reference & page # for your statement. In his book Boat Owners Mechanical and Electrical Manual he shows how to solder, which is good, but he also says the following.
Originally Posted by Nigel Calder from Boat Owners Mechanical & Electrical Manual Pg. 122
Soldering is a controversial subject. A properly soldered connection creates the best electrical connection, but all too often the soldering is not done properly. In any case, ABYC regulations require that every joint have a mechanical means of connection other than solder. The reason for this is that if the joint gets hot (through excessive resistance or a high current flow) the solder may melt and the joint fall apart. So solder often becomes just an adjunct to a crimped connection, but in this case the solder wicking up the cable creates a hard spot, which is then liable to fail from vibration. The concensus among professionals is that a properly made crimp, done with the proper tools, is frequently a more reliable termination than soldering.
I don't know how you read that but I don't read it as a recommendation but rather a caution about using solder.
______
  #166 (permalink)
Old 05-28-2009
eolon is on a distinguished road
Wow, hot topic. Tragically, I have a job so I can't endlessly post superfluous minutia, maybe when I retire =)
Soldering = the Devil, yeah, we get it.
Of course, that doesn't exactly jive with solder traces on PC boards, does it? That solder runs just about everything in your life, from your computer, to your car, to your doorbell.
Anyhow, I'm sure you're right, I just thought you might be interested in an alternate opinion. Guess not.
Best Regards,
e
  #167 (permalink)
Old 05-28-2009
tommays's Avatar
tommays is on a distinguished road
Best Regards,
Its pretty MUCH the entire Marine Industry and the Coast Guard who has final say over most things on boats who want things crimped
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #168 (permalink)
Old 05-28-2009
Maine Sail's Avatar
Best Regards,
e
Soldering is not the devil. No one ever said it was. perhaps you missed the whole point about the vast majority of boat owners not having a CLUE how to properly solder and this is the main reason why it is not advised on top of heat from a resistance situation. There is lots of solder on boats but mostly in PC boards as you mentioned. The computer I am on now has both crimps, many of them, and soldered PC boards. The two methods both make fine electrical connections..
As I have said before solder makes an excellent electrical connection but that is ONLY HALF the story operator error is the other..
We are always interested in an alternate opinion but your original post was this:
The correct answer is both.
Solder and then crimp electrical connections.
Glad I could help...
And NASA says:
"4.3.4 Crimping. Stranded wire shall be used for crimping (Requirement). Crimping of solid
wire is prohibited. Crimping of solder tinned wire is prohibited."
I simply disagreed with the methodology of solder first then crimp as do most standards, manufacturers, NASA and the US Military.
Crimping first then soldering is fine provided it is done correctly, which most boaters just don't know how to do.
Again, no one is disputing that solder makes an excellent electrical connection but the application, environment and installation techniques are being debated.
______
  #169 (permalink)
Old 05-28-2009
Most of the crimps in a computer or electronic device are to hold heavy components on to the device where solder might not have enough mechanical holding power. Things like plugs that come out through the case that the user interacts with directly are often crimped on to the board so that they won't break free when the user does what users do. Electrical connections are still solder, they are just crimped too to help hold them to the boards.
  #170 (permalink)
Old 05-28-2009
hellosailor's Avatar
Come on, sd, you and I both know that the meters-and-feet "mixup" was totally bogus. A very clever cover story that NASA put out trying to explain why 2/3 of the 53(?) Mars landers/missions have "failed" to date.
If the public ever was told the real truth--that the Martians have shot down 2/3 of the UFOs that have reached Mars from Earth--there could be chaos in the streets. Better to take one for the team, and come up with a really really clever "Doh!" excuse instead.
(WEG)
Advice, please on crimping wire connections... FrankLanger Gear & Maintenance 65 07-26-2009 01:23 PM
Rope Cutting Tip for Weller 8200 Soldering Gun? SEMIJim Gear & Maintenance 6 11-18-2007 11:17 AM
Turnbuckles - Stainless versus Aluminum Finallybuyingaboat Gear & Maintenance 9 10-05-2007 10:47 PM
da versus high tech sailon2win Racing 5 10-05-2004 05:07 AM
Power versus Sail Tom Wood Cruising Articles 0 12-23-2000 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
