Crimping versus Soldering - Page 29 - SailNet Community
 2Likes
post #281 of 286 Old 01-07-2013
Send a message via Skype™ to smresq
Re: Crimping versus Soldering
Many good replies and advice...
Thanks,
smresq is offline
post #282 of 286 Old 05-24-2013
I have added dipping the end of the wire into dielectric (silicon) grease or squeezing a small amount into each end of the crimp / splice; on the notion that it keeps water and corrosion out as a secondary defense; in addition to the other good ideas before this. It's easy and quick-may do nothing more than make me feel better?
Happy Mullet is offline
post #283 of 286 Old 05-24-2013
asdf38's Avatar
Dialectric grease is an insulator. I don't think it's advisable to dip the wires in it before crimping. Squeezing it in afterward may be helpful except if you have adhesive lined heat shrink, in which case it seems like it would prevent a good bond.
asdf38 is offline
post #284 of 286 Old 05-25-2013
mitiempo's Avatar
Dielectric grease (which is an insulator as posted above) adds nothing to a good crimp done properly with heatshrink.
Brian
mitiempo is offline
post #285 of 286 Old 06-17-2013
Does anyone use a "conductive" grease in their crimps? This is a link to the one sold by sailors solution:
LED lighting, soundproof, Sailor's Solutions Inc.
I've never used it but I'm thinking it would help with the corrosion issue but reduce the mechanical strenth of the crimp because of a reduction in friction?
LinekinBayCD is offline
post #286 of 286 Old 06-17-2013
crimp it, then solder it, then heat shrink, then use heat shrink tape. It is best to do it right the first time.
desert rat is offline
Advice, please on crimping wire connections... FrankLanger Gear & Maintenance 67 10-09-2012 08:22 AM
Rope Cutting Tip for Weller 8200 Soldering Gun? SEMIJim Gear & Maintenance 6 11-18-2007 11:17 AM
Turnbuckles - Stainless versus Aluminum Finallybuyingaboat Gear & Maintenance 9 10-05-2007 10:47 PM
da versus high tech sailon2win Racing 5 10-05-2004 05:07 AM
Power versus Sail Tom Wood Cruising Articles 0 12-23-2000 08:00 PM
