- Quick Menu
02-15-2008
Not just vibration, but occasional access to panels, or the occasional tug on the harness will cause enough mechanical fatigue in a solder joint to cause it to fail. Soldering requires a long list of prerequisite conditions to create a satisfactory joint, and even then, as mentioned you have created a solid strand vice multistrand. That alone is reason enough not to solder. You don't use solid wire on a boat for the same reason.
02-15-2008
Handsome devil
Well I for one
am glad you brought it up again..Its amazing what Im still learning after 50 years...I knew about cold welding in cable manufacturing and the like but this is the first time I have seen evidence of it being possible with crimp fittings...I must be doing them very wrong as you can pull mine apart without much effort..I have used then for years as what I thought was a slip shot replacement for a good soldering...I vacillate between whatever tool is handy to crimp with... however I cant say that the cheap 4.00 crimpers do any better job then a 4.00 pair of side cutters...but now at least I know why I should go buy a 30.00 crimper...Old dogs do learn new tricks...Thanks to everyone who posted especially the links to thoes sites showing propper crimps...
02-15-2008
It may not be the crimpers but the proper size connectors that you need to use.
S/V Scheherazade
I had a dream, I was sailing, I was happy, I was even smiling. Then I looked down and saw that I was on a multi-hull and woke up suddenly in a cold sweat. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
02-15-2008
Handsome devil
Oh I have always used
the right size..albeit cheap ones..There is most likely half the culprit
Off topic...how do you guys get your quotes in that nice blue box?
02-15-2008
Alex, not full of crap
click the quote button at the bottom of the post you want to reply to.
Charlie
Courtney's my Dancing Angel
Where am I, and where's my paddle?
It's not impossible, it just costs more.
Give me ambiguity, or give me something else.
02-15-2008
Wandering Aimlessly
Or, to customize the quote, start with [quote=anything you want] ,what you want to quote, and end [/quote (plus the rear bracket)
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love. JCP
Music on the Wind - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
02-15-2008
Handsome devil
PBzeer
Thats the one I needed...Not sure I understand but Ill play with it...Thanks
02-15-2008
"but now at least I know why I should go buy a 30.00 crimper..."
More like $50 for the crimper. That would be a ratcheting one with removable/replaceable dies at the business end.
And, you need proper crimps as well. The cheap stuff at the auto store is junk. Real crimps are carefully designed and made on machinery that was not worn out and then sold to someplace in China. They are matched to SAE or AWG wire sizes, and include an inner seamless copper sleeve to grip over the wire. No inner sleeve? Then it is junk, not a proper crimp terminal.
With the right wire, a good crimp, and a good crimping tool, you should be able to wrap the wire around both hands and PULL and not have it come out of either side of the crimp. The wire should break first, if need be.
02-15-2008
Best Looking Moderator
Yep. I give all my crimps the "tug test". Fail the tug test, and I start all over.
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
02-15-2008
Handsome devil
Cheap insurance
Quote=More like $50 for the crimper. That would be a ratcheting one with removable/replaceable dies at the business end./quote
Thanks for the details
Edit : Well that one didnt work..
| Thread Tools |
Search this Thread |
