Crimping versus Soldering - Page 6 - SailNet Community
 2Likes
post #51 of 286 Old 02-16-2008
Handsome devil
Stillraining's Avatar
Yeikes!!
Originally Posted by US27inKS View Post
These are the connectors I use in my auto shop. They're the best I've found, but you can't just go to the store and buy some. BTW the cost for these is about a buck a piece depending on the style of connector.
http://www.wurthusa.com/project/en/l...th=03.0141.jpg
Well...At least they have a built in heat shrink..
Stillraining is offline
post #52 of 286 Old 02-16-2008
Alex, not full of crap
werebeagle's Avatar
As for the quotes, I just use the quote button, and then edit the text if I don't want all of it in there, of copy and paste multiple times before editing if I want multiple quote boxes. I find it's easier than trying to manually enter in the proper quote brackets.
Charlie
Courtney's my Dancing Angel
Where am I, and where's my paddle?
It's not impossible, it just costs more.
Give me ambiguity, or give me something else.
werebeagle is offline
post #53 of 286 Old 02-16-2008
Handsome devil
Thanks
I simpler idea for a simple Man...
post #54 of 286 Old 02-16-2008
artbyjody's Avatar
What I am getting from this is that quotes are important in the crimping process as well...
Another simple technique is to tie the corresponding wires together and then twist the heck out of the stripped portions and then electrical tape the heck out of it (with good marine grade tape of course)....it will survive the tug test but not many others...
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #55 of 286 Old 02-16-2008
Handsome devil
Yep
Thats what I do when broke down at night lee shore or not....
Sorry for the public schooling of an old thick skulled loggerhead...
post #56 of 286 Old 02-16-2008
werebeagle's Avatar
I've worked on some houses where that was the thought also. The connection was so reliable, that they decided not to put it into a junction box, but just bury it behind the drywall.
Charlie
post #57 of 286 Old 02-16-2008
artbyjody's Avatar
I have too - and will do it if in a pinch - but nah either the crimping or soldering - both actually if done properly with the right materials imho work equally as well... the problem with crimps is there is one moisture point ingress unless the heat shrink cover where the spade starts....it doesn't take much and the crimp will outlast the wiring any day as it doesn't suck moisture...my last post was merely in jest....
-- Jody
S/V "
post #58 of 286 Old 02-16-2008
The one down in New Bedford had some of the Ancor electrical terminals, along with the supplies one would need to make docks. This is probably due to the importance of the waterfront and fishing industry in the area.
BTW, the brand is Ancor, not Anchor, which is what you've got too many of to begin with.
Originally Posted by halekai36 View Post
A select few Home Depot stores, mostly in Florida, do carry a very small assortment of anchor wire and connectors. Unfortunately, none of the Home Depot stores in the North East, that I've been in, carry Anchor products.
sailingdog is offline
post #59 of 286 Old 02-16-2008
Freesail99's Avatar
Is that code ? I always thought if your behind drywall, your in a junction box. That is what I've always done.
S/V Scheherazade
Freesail99 is offline
post #60 of 286 Old 02-16-2008
Freesail, I believe I hear the local fire marshal calling your name.
Advice, please on crimping wire connections... FrankLanger Gear & Maintenance 67 10-09-2012 07:22 AM
Rope Cutting Tip for Weller 8200 Soldering Gun? SEMIJim Gear & Maintenance 6 11-18-2007 10:17 AM
Turnbuckles - Stainless versus Aluminum Finallybuyingaboat Gear & Maintenance 9 10-05-2007 09:47 PM
da versus high tech sailon2win Racing 5 10-05-2004 04:07 AM
Power versus Sail Tom Wood Cruising Articles 0 12-23-2000 07:00 PM
