  #61 (permalink)
Old 02-16-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
Freesail, I believe I hear the local fire marshal calling your name.
Why for putting wires into a junction box, rather then use a crimped connection as suggested ?
S/V Scheherazade
  #62 (permalink)
Old 02-16-2008
Maine Sail's Avatar
The one down in New Bedford had some of the Ancor electrical terminals, along with the supplies one would need to make docks. This is probably due to the importance of the waterfront and fishing industry in the area.
BTW, the brand is Ancor, not Anchor, which is what you've got too many of to begin with.
Yep honest sp. mistake do it all the time...
SD which ratcheting crimper do you use I need to replace mine and there are sooo many options? I currently have the Ancor ratcheting but am not totally impressed with the quality of the crimp.
I'm considering the Klein T1710.
Course if I had not misplaced my $$$$$$$ AMP crimper then, well, I would not need a new one..
______
-Maine Sail / CS-36T
  #63 (permalink)
Old 02-16-2008
werebeagle's Avatar
Alex, not full of crap
werebeagle will become famous soon enough werebeagle will become famous soon enough
Originally Posted by Freesail99 View Post
Is that code ? I always thought if your behind drywall, your in a junction box. That is what I've always done.
By code, all electrical connections have to be accessible when the house is finished, and in a UL approved junction box. You can't just cover the box behind drywall, there has to be a removable cover plate. You also can't decide to add a cabinet in front of an outlet without cutting out the back for access to the outlet and the connections.
Charlie
Courtney's my Dancing Angel
Where am I, and where's my paddle?
It's not impossible, it just costs more.
Give me ambiguity, or give me something else.
  #64 (permalink)
Old 02-16-2008
Freesail99's Avatar
Thanks Charlie.
S/V Scheherazade
  #65 (permalink)
Old 02-16-2008
Freesail-
Charlie's nailed why I said the local fire marshal would want to be talking to you.
  #66 (permalink)
Old 02-16-2008
That looks a lot like the crimper I keep in my main tool box at the house, which is made by Ancor.
I also have one of these Ancor crimpers aboard the boat, but it isn't as good IMHO.
  #67 (permalink)
Old 02-16-2008
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
I've not used the ratcheting type, although I could see some benefit to them in a tight space-that is, if you can get the head of them into said space! I've found the traditional Klein Pliers, the tool the company is most famous for and they're actually crimper/cutters, to be the most effective. You can see a photo here:http://www.tools-plus.com/klein-1006.html
If you're using the conventional strippers/crimpers you're going to have a quantifiable increase in life satisfaction by purchasing a pair. Available at Home Depot and electrical supply houses. Channel Lock makes a knock-off version as well.
Wm. F. Buckley, Jr.
  #68 (permalink)
Old 02-16-2008
Maine Sail's Avatar
Originally Posted by sailaway21 View Post
I've not used the ratcheting type, although I could see some benefit to them in a tight space-that is, if you can get the head of them into said space! I've found the traditional Klein Pliers, the tool the company is most famous for and they're actually crimper/cutters, to be the most effective. You can see a photo here:Klein 1006 Crimper-Cutter at Tools Plus
Sailaway...
Unfortunately, that crimper you use is not designed or intended for use on insulated terminals such as those made by Ancor, FTZ or AMP. That tool is for non-insulated terminals... Just a heads up...
______
  #69 (permalink)
Old 02-16-2008
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
Crimp, solder, whateva. Get some Romex and wire nuts, a 12 pack, and call it a day.
Dictated, but not read.
  #70 (permalink)
Old 02-16-2008
Maine Sail's Avatar
What no women ????
______
Advice, please on crimping wire connections... FrankLanger Gear & Maintenance 65 07-26-2009 12:23 PM
Rope Cutting Tip for Weller 8200 Soldering Gun? SEMIJim Gear & Maintenance 6 11-18-2007 10:17 AM
Turnbuckles - Stainless versus Aluminum Finallybuyingaboat Gear & Maintenance 9 10-05-2007 09:47 PM
da versus high tech sailon2win Racing 5 10-05-2004 04:07 AM
Power versus Sail Tom Wood Cruising Articles 0 12-23-2000 07:00 PM
