Crimping versus Soldering - Page 8 - SailNet Community
 2Likes
post #71 of 286 Old 02-16-2008
Not So Senior Member
Sapperwhite's Avatar
Originally Posted by halekai36 View Post
What no women ????
Of course, who do you think is going to twist all that Romex and put on the wire nuts?
Dictated, but not read.
Sapperwhite is offline
post #72 of 286 Old 02-16-2008
Also, ratcheting crimpers tend to give a much more consistent crimp, since the jaws won't release until the crimp reaches a set point.
Sailaway...
Unfortunately, that crimper you use is NOT designed and is NOT intended for use on insulated terminals such as those made by Ancor. That tool is for NON-INSULATED terminals... Just a heads up...
sailingdog is offline
post #73 of 286 Old 02-16-2008
Owner, Green Bay Packers
halekai,
I'm curious then as to why Klein stamps on the side of the jaw, "ins" and "un-ins" adjacent to the two crimping jaws. One of the jaws makes a crimp while the other makes more of a swage. I prefer uninsulated terminals, where possible, adding shrink tubing after the crimp.
edit for more info:
I've found that anyone with decent hand strength can achieve the same results with out the need for ratcheting. Ratcheting cutting tools generally shine where larger diameters are being cutt or crimped. I'm not against them for the discussed usage, I've just never been less than completely satisfied with the Klein pliers.
Wm. F. Buckley, Jr.
sailaway21 is offline
post #74 of 286 Old 02-16-2008
For more on this cutting edge of technology topic, including important input from NASA as well as the Republic of Ireland, you can read here:Advice, please on crimping wire connections...
There is a great deal of good info amidst the passion.
Wm. F. Buckley, Jr.
post #75 of 286 Old 02-16-2008
Ancor brand terminals and crimps are carried in the Home Depots in the metro NYC area, in the "eletrical" supplies sections somewhere near the tools (locked up) and switches and tape. Although HD charges some of the highest prices I've seen for electrical tools and meters, and often doesn't have great quality. (Very disappointing.)
OK guys, now let's stop screwing around with crimping tools and start doing it the right way. First, you wrap some fine copper sheet over the two spliced wires. Then you lay about 1/16" of C4 or Semtex around the copper cladding, press in a detonator, and wire it back to the companionway. Once you've got them all set, hook up the power and WHAM all the wires are welded, very nicely, very quickly.
Or, you can buy the explosive crimping sleeves in the "Sears Really Really Special Tool Catalog" but you'll have to go behind the doors in the back room and show ID before they'll let you have one. The ones from Sears are pretty good, there's a microbattery and microdetonator with timer all built into it, for a one-shot use with no extra wires to run. [VBG]
hellosailor is offline
post #76 of 286 Old 02-16-2008
great, now we're gonna get monitored by homeland security
xort is offline
post #77 of 286 Old 02-16-2008
Handsome devil
Stillraining's Avatar
Read it all Sway...
Every post ...now you know why my wife is telling me I'm addicted to you guys...
Some good stuff there for sure...I think I have enough information to carry on from here...Thanks Guys...
Hay by the way Sway...I use to Drill for the black water..
Stillraining is offline
post #78 of 286 Old 02-16-2008
"great, now we're gonna get monitored by homeland security"
Only for about 3 minutes.
Then the men in black will figure out we're ass's full of crap and ignore us. As it should be.All is right with the world.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
cardiacpaul is offline
post #79 of 286 Old 02-16-2008
Maine Sail's Avatar
Originally Posted by sailaway21 View Post
halekai,
I have no idea why and was only referring to the crimpers in the link you posted and the specs on those specific crimpers: http://www.tools-plus.com/klein-1006.html
Highlights:
Klein 1006 Crimper-Cutter
  • For crimping non-insulated solderless terminals
  • Accommodates wire from No. 10 to 22 AWG
  • Specially hardened wire cutters in nose
  • Length 9-3/4"
  • Lifetime guaranteed ~ made in U.S.A.
My guess is that the ones you linked to are not the same as the ones you actually own??
______
-Maine Sail / CS-36T
Maine Sail is offline
post #80 of 286 Old 02-16-2008
halekai,
My error. I must be infected with the same virus as the sailnet store. (g) Yes, mine do have a jaw for both insulated and un-insulated and those are the red handled ones found at the Home Marina and electrical supply houses.
Wm. F. Buckley, Jr.
Advice, please on crimping wire connections... FrankLanger Gear & Maintenance 67 10-09-2012 07:22 AM
Rope Cutting Tip for Weller 8200 Soldering Gun? SEMIJim Gear & Maintenance 6 11-18-2007 10:17 AM
Turnbuckles - Stainless versus Aluminum Finallybuyingaboat Gear & Maintenance 9 10-05-2007 09:47 PM
da versus high tech sailon2win Racing 5 10-05-2004 04:07 AM
Power versus Sail Tom Wood Cruising Articles 0 12-23-2000 07:00 PM
