Old 02-15-2008
Sixbrothers is on a distinguished road
Barrier coat prep
I'm ready to barrier coat my new (rebuilt) rudder. I've got my Interprotect 2000E etc. The directions on Interlux's web site say that I should wash it with boat soap then sand it and finally wipe it down with Interlux 202 solvent wash. My question is: is there any other product I could use instead of this solvent wash? I don't mind purchasing it but the nearest marine store is over an hour and a half drive away. I want to start on it right away so I don't want to wait to get it shipped.
Of course I want to do this right but if this stuff is some common product with a marine name and price on it I would rather buy local and save time, gas, and money.
Thanks
Old 02-15-2008
Interprotect 202 is a mix of naphtha petroleum distillate with several other compounds, like xylene, pseudocumene, cumene, cyclohexanone and methyisobutyl ketone added in. Mainly, it is designed to lift off oils very aggressively.
I believe you can probably use acetone or denatured alcohol to wash the boat down. Basically, it is to get any airborne grease and dirt off the surface. Remember to use two cloths... one to wipe the solvent on, and one to wipe it dry and pick up any contaminants it may have lifted off the surface. Change the cloths frequently.
If you have any questions whether acetone or denatured alcohol would be better, call International paints, who makes the Interprotect and ask them. I would guess that they'd recommend the Acetone...since it is a bit more aggressive than the denatured alcohol.
Another possible solvent for you to use would be Xylol, which may be available at your local hardware store. It is primarily xylene... and should work fairly well.
Old 02-15-2008
jrd22's Avatar
Courtney the Dancer
Check your local auto paint store if you have one in your area. There are several commercial products that are designed as a "final wash" prior to applying two part finish coats. Worth a try, might save you a long drive. I hate being ready to do the job and then something like this causes a delay, frustrating. Good luck.
John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 02-15-2008
Thanks for all the advice. I will investigate.
Old 02-15-2008
pegasus1457's Avatar
Arf!
pegasus1457 is on a distinguished road
John
And what if it doesn't work as well as the Solvent Wash 202? And the barrier coat starts to peel off the rudder after one season? The OP has invested $100 or more in Interprotect 2000. If it doesn't bond properly, he has to do the whole thing over again. Sand the whole rudder, solvent wash, new barrier coat?
If it were me, I wouldn't take any chances. BTW I am about to do the same job on my bottom in 6 weeks when the temps here get above 60F.
Fluctuat nec mergitur
Old 02-15-2008
That's kind of why I told him to call International Paints... to ask about whether acetone, denatured alcohol or Xylol will work in place of Interlux Fiberglass Prep Wash 202.
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 09:18 AM
Applying Barrier Coat Sixbrothers Gear & Maintenance 3 02-12-2008 09:23 PM
Barrier Coat - Amerlock 400 by Ameron ? dougshipl Gear & Maintenance 5 12-31-2007 01:10 AM
Is Vinyl Antifoul better over Epoxy Barrier Coat pds Gear & Maintenance 3 08-27-2001 12:27 PM
Barrier Coat stupidgringo Gear & Maintenance 0 08-23-2001 04:53 PM
