02-16-2008
Owner, Green Bay Packers
I think the pipe dope works better on the smaller fittings, under 1/2". I generally just use teflon on anything larger but know those who even use both! Probably one or the other and you'll be fine.
If you're putting something together that you'll be taking off fairly frequently, like a filter bowl, or that's made of plastic threads, I'd strongly recommend silicone grease. Available at your local pool store.
Wm. F. Buckley, Jr.
