What is this? Why is it on my boat? - Page 8 - SailNet Community
Blogs
  #71 (permalink)
Old 02-16-2008
Lion35 is on a distinguished road
Could it be the manual backup handle for your windless? Does the hose have a significantly larger diameter, or is it tight on the rod? If it's larger maybe they used it for attempted floatation?
Or maybe it just holds up the wet locker its mounted in with those fancy clips?
  #72 (permalink)
Old 02-16-2008
craigtoo's Avatar
Barkeep - Sailor's Pub
craigtoo will become famous soon enough craigtoo will become famous soon enough
Send a message via AIM to craigtoo Send a message via Yahoo to craigtoo Send a message via Skype™ to craigtoo
No Windlass...
The device is 4 feet long. So I dont' think it's a handle.
It won't float.
Thanks for trying...
Stumping Sailnet.... Wow...Didn't think it could be done...!
-C2
1987 Sabre 34 "Saoirse"
Meet me at the
I love
  #73 (permalink)
Old 02-16-2008
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Why not?
I assume your boat has a spinnaker? Could this be some kind of funky hand held twing for playing the sheet? You would need to mount a block on the lanyard and then the sheet through the block. This would allow the foot of the sinnaker to ride higher. Was the PO into racing?
Just stow it, preferably where you found it until it becomes a parent.
  #74 (permalink)
Old 02-16-2008
sandiegosailor is on a distinguished road
One more guess.....She has a retractable keel with about a 4 ft draft....This thing is about 4 ft....Could it be some sort of manual depth gauge?
  #75 (permalink)
Old 02-16-2008
Looking's Avatar
Looking is on a distinguished road
What about a tiller extension for the dink? But they why would it be stored in the hanging locker???
Do you have a settee that pulls out to a berth? Could this be a support for that?
"It isn't that life ashore is distasteful to me. But life at sea is better."
Sir Francis Drake
  #76 (permalink)
Old 02-16-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
Those double hose clamps are mounted with such precision.... measure the exposed ends.. if they are exactly the same length we can safely assume the PO was a Virgo (my wife is one and it drives me nutz!!!)
Maybe it is just someones way of storing some spare parts...
  #77 (permalink)
Old 02-16-2008
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
Is the boat equipped with a Drogue
could be used to hold the mouth open and keep it weighted....?
  #78 (permalink)
Old 02-16-2008
craigtoo's Avatar
It may have had a chute at one time... But it hasn't for a long time.
It wasn't raced by the PO.. but could have been by the PPO.
Could it be some sort of stand for a BBQ? Again.. why below and not in storage in the cockpit...?
Let me check that out...
-C2
Meet me at the
I love
  #79 (permalink)
Old 02-16-2008
craigtoo's Avatar
Wow... we've just passed the "Crimping vs. Soldering" thread in number of views...!!
-C2
Meet me at the
I love
  #80 (permalink)
Old 02-16-2008
JohnRPollard's Avatar
Moderator
Okay Craigtoo,
Hasn't this been fun? But we've made you suffer long enough. All of us old timers know exactly what the device is, we were just enjoying this little prank at your expense. No hard feelings, I hope?
What you have is found on most boats built after about 1975, when certain new electrical safety standards were promulgated. Usually it is hidden away in an obscure location (often the underside of the deck inside a cockpit locker) but some builders felt it was important to install it more prominently/accessible.
What that device is is a master electrical circuit breaker. By clipping it into its position, the master electrical circuit for the entire boat is completed. Think of it as sort of a giant fuse. On the back side of those clips they are connected to some very heavy gauge wire, which you may not be able to see because they usually embed it in the cabinetry. The center portion of the conducting rod is insulated with rubber hose, so that you can grab on to it and remove it from the clips without getting a shock.
Whatever you do, DO NOT remove this mega master fuse for any extended periods of time. That is because not only will you bypass the principal surge protection/absorption for your electrical system, but you will also cause 12V electricity to bleed outside of the hull via the emergency secondary bypass, which will quickly burn through your zincs and begin eating at your bronze thru-hulls.
Sorry to toy with you. Hopefully this explanation puts the mystery to rest...
Construction of a PVC (Divinycell) cored boat Giulietta Sailboat Design and Construction 8 10-19-2007 06:46 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 08:00 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 09:00 PM
Understanding the Racing Rules, Part Three Dean Brenner Racing Articles 0 09-09-2002 09:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
