Tides Marine STRONG mainsail track system - Page 2 - SailNet Community
post #11 of 12 Old 02-20-2008
phallo 1, Gustav 0
phallo153's Avatar
I think that would be correct... the Strong sail track, from what I've seen of it, is pretty simple to install and works well. IIRC, it installs by attaching to the existing sail slug track on the mast.
Correct. Tides Marine will send you a set of gauges to measure the width and depth of the existing track and slot on the mast. The track is then milled to those specifications.
In most cases, modifications to the mast gate will have to be made - in the picture below, my mast gast was extended from 1.5" to about 3", both sides of the slot. It is imperative that the opening by filed very smooth - the smallest burr will gauge the track and eventually cause it to bind. A little dish soap and it slides right in. Below the mast gate the back of the track is flat, with several screws and backing plates that fit into the mast track and are then tightened to keep the track in place.
phallo153 is offline
post #12 of 12 Old 06-01-2012
Re: Tides Marine STRONG mainsail track system
I added a Tides Marine Strong Track from Sail-Care to my boat early this year. The documentation was easy to understand and a breeze to install. The track system was up and ready to use in an hour and a half to complete. The guys at Tides and Sailcare have my vote as the system changed "Dove" VD# 606209 instanly into a great pleasure to sail. I also added Sail-cares MarkIV Cradle to the boat in order to tame the 4 batten main. My wife even loves the addition which makes hoisting and doucing the main extremely fast. Love it!
Far Side is offline
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 08:00 PM
Strong mainsail slide system clayton Gear & Maintenance 3 06-12-2002 07:32 PM
loose footed or track mainsail soverel28 Gear & Maintenance 5 05-21-2002 05:08 AM
