Water Heater - Page 2 - SailNet Community
post #11 of 14 Old 02-16-2008 Thread Starter
theartfuldodger's Avatar
Send a message via Skype™ to theartfuldodger
that's why I'm asking the question, under marine they have a heater and trying to understand how it works, wondering if it warms water and pipes it to heater cores in the boat like hot water heaters in a home or am I way off on this
Brake Free
Lake Ontario
42 CC Passage
theartfuldodger is offline
post #12 of 14 Old 02-16-2008
Wandering Aimlessly
PBzeer's Avatar
Appears to be an on demand type, don't know how well it would work in your application.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #13 of 14 Old 02-16-2008
Maine Member
BELLATRIX1965's Avatar
Yes, it's a hydronic water (space) heater!
Artfuldodger:
Yes, you are looking at a hydronic type, diesel-fired heater. This amounts to the equivalent of a boiler in a house - that is, it uses a diesel fire to heat water, which then is piped (usually via hoses) to your domestic water heater, and also can be piped to small radiators (usually with a small 12 V fan behind them) in order to heat your cabin, head, vee berth, etc.
I am considering one of these for my boat as well. Another maker is Webasto.
http://www.navstore.com/webasto.aspx
The unit that you are looking at is made by Espar, and these are used not only for boats, but big rig trucks, in order to heat the sleeper cabin as well as to keep the diesel engine warm when shut down overnight. Sometimes you can get better prices on these units via a truck supply company vs. the always-more-money "marine" version (same thing)!
Any of these units will require a separate fuel supply pump (taking suction from your main engine diesel tank), and a small exhaust line (insulated, corrugated stainless steel) usually leading to a through fitting in the boat's transom.
Good luck, and let us know how your project turns out!
Happy sailing!
BELLATRIX1965 is offline
post #14 of 14 Old 02-16-2008
moderate?
camaraderie's Avatar
Here's espars brochure on how the whole thing works. Looks like it can be used for all hot water needs including heating. Interesting but complex system.
http://www.espar.com/documents/marine.pdf
camaraderie is offline
Flushing/testing/preping an old water system on a new old boat tenuki Gear & Maintenance 8 04-19-2007 11:33 PM
hot water heater question primerate84 Gear & Maintenance 8 10-19-2006 09:24 PM
Gifts from the Rain Gods Doreen Gounard Cruising Articles 0 03-18-2004 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 08:00 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 06:59 PM
