rain leak in MacGregor 26x - SailNet Community
Blogs
Old 05-10-2002
newuser is on a distinguished road
I have developed a rain water leak in a 1997 MacGregor 26x. I have caulked all logical leak points. The water shows up in the stern leaking from the inner liner seam just forward of the motor sump drain hose. It leaks into the cabin area, not the bilge. I am stumped as to how to even find the source.
Old 10-09-2007
artsounds is on a distinguished road
Hello,
I have a similar problem in a 1990 M26, did anyone ever found the cause?
Thanks
Old 10-09-2007
miatateer is on a distinguished road
Have no idea if this will help. We were getting water in our '91 M26 everytime it rained. One nite, I crawled in the boat will it was in the driveway (ah, trailer sailers!) and its was pouring rain. Using a flashlight at a very glancing angle to the cabin side, I notice muitlple trickles coming from the joint between the cabin roof/deck and the hull. Funny thing was these trickles were evenly spaced. I figured they were coming in thru the bolts that held the top and hull together and those bolt heads are coverd by the rub rail. So I ran a bead of clear caulk along the top edge of the run rail around the entire boat. Amazingly the boat has been 100% dry since then...16+ years.
Good luck
Old 10-09-2007
camaraderie's Avatar
moderate?
Miatateer...yeah but what will happen when you put her back in the water!!?? (g)
Welcome aboard!
Old 10-09-2007
RickLaPaz's Avatar
RickLaPaz is on a distinguished road
Good luck
Congrats, you're now ready for the Indian Ocean.
(Whoops, wrong thread).........
Old 09-18-2009
saltyfoam is on a distinguished road
I just bought a 98 Macgregor 26X and fixed two leaks in the stern. One originated from the two wires that come off the throttle. I caulked where those wires came into the pipe at the deck. The other leak came from a void in the fiberglass in the outboard trunk around the drain pipe. I cut through a few layers of fiberglass to cut away the void, then lay new fiberglass over that area. Seems dry so far. ;-)
Old 09-18-2009
CaptKermie's Avatar
CaptKermie is on a distinguished road
This is a rather old thread, any Mac Owners looking for Mac specific advice should go here:
MacGregorSailors.com
Old 09-20-2009
SiXeVeN is on a distinguished road
I had a similar problem. The water was originating from the wires going through the cockpit floor. Water tracks along the steering and throttle cables and runs down onto the rear birth fiberglass ceiling shell. In a very heavy rain, the water can actually swell over the small pipe in the floor and frankly flow into the birth ceiling. Seal that hole and you should be good.
I used a rubber baffle and marine silicone. Dry ever since.
Universal m35 leak at drain plug sailingdeacon Gear & Maintenance 1 01-07-2005 12:21 PM
Lewmar opening port leak ref_123 Gear & Maintenance 4 09-29-2003 10:36 AM
Island Trader water tank leak swardfullsail General Discussion (sailing related) 1 02-11-2003 09:28 AM
Fuel Tank Leak silversea Gear & Maintenance 1 02-13-2002 05:05 AM
mast boot leak rads Gear & Maintenance 4 11-01-2000 11:22 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
