Found soft spot on hull after putting on trailer - Page 2 - SailNet Community
post #11 of 12 Old 02-18-2008
IF the reason the area is "soft" is a detached stringer or floor, you'd be better off re-attaching the stringer. Adding some glass to the hull isn't a bad idea either, but you should do it to both sides, to keep the boat symmetrical.
sailingdog is offline
post #12 of 12 Old 02-19-2008
Once known as Hartley18
Classic30's Avatar
Dock
I had to re-attach a couple of stringers on our boat (funnily enough, in about the same position - port side aft of the centercase!) and found that, even though it looked easy, trying to sand old fibreglass tape in the corner on both sides of the stringer was a real PITA!!
I tried to cut the old tape with a Dremel tool, but couldn't get into the gap. In the end, I scratched the bottom paint with coarse sandpaper, broke off as much of the old tape as I could get to, poured epoxy into the gap and put a bit of glass tape over the top for good measure - and painted the whole mess so no-one would know Will it hold? I think so.. but it's definitely not as good as it should be.
Yeah.. otherwise you'll sail 'round in circles!
Classic30 is offline
Glassing hull GreenEarth General Discussion (sailing related) 18 06-20-2009 12:52 AM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 02:07 AM
Bottom refinishing on trailer? aflanigan Gear & Maintenance 2 10-10-2003 04:10 PM
hull construction cgha33 Boat Review and Purchase Forum 4 05-23-2003 08:11 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 09:00 PM
