Old 02-18-2008
dtallman is on a distinguished road
Solar Micro Vent Location
Hello Folks,
I seek your opinion.
I have a 1978 25' Catalina. There are two vent ports dead center on the deck: one above the forward berth, the other above the head.
I'd like to place a Micro vent in one of the port locations; thus, sparing myself from creating another hole in the deck.
My concern is that either one of these locations may cause the head sale sheets to become snagged on the mushroom style vent cap when tacking.
Any thoughts regarding the placement of the Micron vent?
Better ideas out there?
Much Obliged.
Deric
Old 02-18-2008
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
They do make devices that will protect your mushroom vents from being snagged. Just add one to each vent you install.
Old 02-18-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
Maybe a link would be helpful, as I don't know what they are. I have two solar vents one in which I install on my forward hatch cover.
S/V Scheherazade
Old 02-18-2008
Hello Folks,
For those who would like to know more about the Micro vents,
please visit: jamestowndistributors website
and perform a search on Micro vents. There is information at the site.
I was advised to install the vent above the head. Traffic on the front of the deck, and the near location to the anchor may be in an area prone to accidents. Moreover, sleeping under a fan -- if installed above the front berth - - may be distracting. Good advice from an experienced sailor.
Deric
Old 02-18-2008
Freesail99's Avatar
The fan can be turned off and in the case of my fans, I can't hear them.
S/V Scheherazade
Old 02-18-2008
If you're talking about these:
Mounting them on the hatch isn't a bad idea. If your sheets can snag on one of these vents, you're doing something wrong or you installed it wrong.
Old 02-18-2008
The design of the vent does help mitigate any sheet becoming snagged, although doing something wrong would be the most likely cause of sheet to become snagged on the unit. Can you imagine that?
I have seen folks who have installed the vents on front hatches. Of course the solar vent is at an angle to the sun... may be good .. or may not.. I don't know.
I shall order one vent. I can always move it from one location to another.
Thanks for the ideas and thoughts.
Happy and safe sailing.
Deric
Old 02-18-2008
Freesail99's Avatar
My vent on the forward hatch works fine. Also 2 vents with one on in-take and the other on out-take works best
S/V Scheherazade
Old 02-18-2008
Slipkiller2's Avatar
I can't reMember
Slipkiller2 is on a distinguished road
I had 74 Catalina 25 that had a cowel vent on the foredeck and it really did get the sheets caught on it. I replaced it wth the exact vent you are asking about and it worked very well. It would catch the sheets now and then and yes a stubed my toe on it every so often but other than that I felt worked pretty well.
location of fuel tank vent sailhog Gear & Maintenance 6 07-29-2007 01:21 PM
Charging with Solar Power Kevin Jeffrey Gear and Maintenance Articles 0 07-28-2003 08:00 PM
Choosing and Installing Solar Panels Sue & Larry Gear and Maintenance Articles 0 11-06-2000 07:00 PM
