Old 02-18-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
I can see clearly now
I can see clearly now through the front panel on my dodger!
Construction detailed here http://www.sailnet.com/forums/gear-maintenance/40623-plexiglass-dodger-window.html
Visibility has changed from bathroom privacy glass to nearly 100% clear. I am pretty excited to try this out underway.. but aunt "gale" is visiting all week it seems
This is pretty much an experiment best I can tell.. never seen anyone else make a window like this. If all goes well it will last the normal life of dodger canvas. My suspicion is the glue joint will start to fail gradually. The way I designed it the plexiglass is trapped in the canvas with additional stitching, so maybe if/when the glue starts to fail it can be nursed along with minor repairs for a while. The pics:
Now for those old ratty side panels... anyone have a recommendation for those?
Old 02-18-2008
JohnRPollard's Avatar
Moderator
Nice work!
Old 02-18-2008
mike dryver is on a distinguished road
yea why not try to heat and bend the same stuff for your front sides and do the same. the panel you made is really clear. do you leave it attached as shown or do you/ can you flip it up for air flow etc.
