Deck to hull leaks - Page 2 - SailNet Community
post #11 of 14 Old 02-19-2008
Once known as Hartley18
Classic30's Avatar
Dock
You might well find that the leak is from the toerail - it was on my boat.
Whilst removing it, resealing it and bolting it all back on is not a trivial task it's not as daunting as trying to glass things up on the inside and if there is any rot/spiders/creepy-crawlies and other nasties hiding under there you can fix that at the same time.
On a boat, out of sight shouldn't be out of mind.
Classic30 is offline
post #12 of 14 Old 02-07-2009
Location: Quilcene, Washington. The west side ot the Hood Canal, at the foot hills of the eastern Olympic Mts.
Leak?
A friend and I were discussing leaks yesterday and he mentioned using smoke. Close up cabin and reverse shopvac to push air/smoke into cabin and have lookouts around boat to look for smoke coming out. I'm not sure how you'd pick a flavor of the lingering smell of smoke afterward. Was an interesting idea.
ptsailor is offline
post #13 of 14 Old 02-08-2009
Capnblu's Avatar
As you are viewing all of the nice little bolts/nuts/screws from inside, and outside of your boat, that will need removing. Think of how the factory must have put it together, and the tools and equipment and labour they had at their disposal to accomplish this kind of job. Now imagine you and all your friends trying to accomplish the same feat, with BETTER RESULTS! I'm not saying don't do it, more like, Are you sure you want to try? I of course don't know your ability, or resources, so take it for what it's worth. Personally I would try to come up with the best solution without popping the deck off. Instead of pressurizing your boat and filling it full of SMOKE, perhaps do the opposite, and establish a vacuum in your boat, and try the soapy water method first. With a vacuum pressure inside, spray soapy water and look for the bubbles. Mark and dry the area. Then pressurize the interior and do the same soap test on the exterior. I think you will have better success than trying to see smoke creeping out a pinhole. Hope this helps somehow.
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
post #14 of 14 Old 02-08-2009
Aspiring to be a Mexican
sww914's Avatar
Soapy water on the outside and compressed air on the inside is a pretty un-messy way to find leaks. Bubbles form at the leaks outside and most boats could probably use a bit of soapy water anyway.
sww914 is offline
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 2 09-12-2012 04:54 PM
Construction of a PVC (Divinycell) cored boat Giulietta Sailboat Design and Construction 8 10-19-2007 06:46 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 09:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 08:00 PM
