Old 02-18-2008
Gulfislander's Avatar
Gulfislander is on a distinguished road
spinnaker sheets
I am getting a cruising spinnaker and would like to know what type and size of sheets do you experienced cruisers use. I was told 1/4" floating line by one friend and told to use 3/8 floating by another because its easier on the hands. Opinions?? - 31' Niagara.
Thanks.
Old 02-18-2008
nolatom will become famous soon enough
Quarter-inch will kill your hands. I'd go half-inch, and in really light air you could use something smaller. Mostly you're tying the sheets on anyway, so you can have two sizes, with one as a spare.
I don't have an opinion on floating or non. If the sheets are getting in the water, the kite isn't flying well anyway.
Out of curiosity, are you talking about a bow-mounted assymmetrical one, or old-school with a pole?
Old 02-18-2008
Quickstep192 is on a distinguished road
The solution is tapered sheets. Thin line kills your hands and thick line is too heavy to let the chute fly in light air. Line that doesn't absorb water is a nice to have. Eventually, the line will get wet and if it stays wet and heavy, it will also make the sail fly poorly in light air. Some folks even go to the trouble of having multiple sets for different conditions.
Old 02-18-2008
It will be a bow-mounted asymmetrical.
Old 02-18-2008
Plumper's Avatar
Sailor
Plumper is on a distinguished road
I would also go with floating tapered sheets. Mine are Warpspeed. The thin end is at the sail (let sit fly better) and the thick end is in your hands (feels good). Get a comfortable thickness.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Old 02-19-2008
ASA and PSIA Instructor
You didn't say how big the boat is, but I'd start with 3/8" as the minimum size for hand comfort, and go larger if the chute size demands. See http://www.neropes.com/LineSelector.aspx for guidance on size. I'd use the basic Sta-Set line or equivalent. I've never heard of the use of floating line for sail control lines, maybe good for the dingy painter...the tapered line is great for racing applications where you'll pay 3 times as much per footfor low weight..shouldn't matter at all on your cruising boat..KISS.
Old 02-19-2008
Plumper's Avatar
Sailor
Floating line is good for A-Sails because they are less likely to go under the boat when you screw up a gybe. They don't make any difference if you use a symmetrical spin or if you gybe it through the forward triangle.
Old 02-19-2008
A dyneema or spectra based line is probably excellent for this, since it is lighter than a dacron line would be, and stronger as well, so you can often go down a size... Dyneema and spectra-based lines float IIRC.
Spinnaker Takedown Basics Dean Brenner Racing Articles 0 04-28-2002 08:00 PM
Spinnaker Fundamentals Steve Colgate Learning to Sail Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Seamanship Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Gear and Maintenance Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Racing Articles 0 06-24-2000 08:00 PM
