Old 02-20-2008
Driver is on a distinguished road
Iron Keel Rust
The snow is almost gone in the yard so I'm dreaming of fun activities...like bottom painting...
We have the dreaded iron keel rust on our Beneteau and I'd like to remedy this issue. There isn't a ton of rust but I don't want to see ANY! I've read of a product called POR 15 that is supposed to "stop rust permanently". I'd have to see it to believe it, but I'm trying to be optimistic.
Has anyone used POR 15 on their rusty keel?
How much prep did you do before applying?
Did you apply a primer after the POR and before your usual bottom paint? (We use Interlux ACT ablative).
Thank you!
Back to the laundry pile....
Old 02-20-2008
billyruffn's Avatar
billyruffn will become famous soon enough
The general rule of thumb for ferrous metals is to make them think they're not in the water. That means you have to surround them with something that won't let the water get to them. Multi-part paint systems will do the trick for a while, but before you coat the metal you must get it clean and clear of all rust. I'm not familiar with the product you mentioned, but many products with similar advertising claims try to 'convert' the rust before painting it (rather than removing it completely by sand blasting, grinding or similar methods). I'm not a chemist, but I think what these products do is strip off the oxygen molecules from the FeO2, replacing the O2 with something inert -- some of the products use phosporic (sp?) acid, which may make a iron phosphate out of the iron oxide (Caveat: a few lines ago I went well beyond my competence....so take this with a grain of salt).
I've used several of the 'converter' products when I've repaired dings on my boat. I've had mixed results. Some areas I've repaired have never had another problem. Others seem to come back every year or so. I'm not sure what I'm doing wrong, but I think that the cause of the rust relapse is when the converter doesn't get rid of all the oxygen. That or the paint system "leaks" and somehow lets water (with it's complement of oxygen molecules) back in contact with the metal.
All I know is that all the pro's I've seen working on steel boats -- grind or blast the metal white bright before they start painting. The also don't let much time pass between the grind/blast and the first coat of primer. Apparently, oxidation of clean bright metal will begin immediately (I think it's called "flash rust") and the sooner you get the oxygen in the atmosphere out of contact with the metal the better off you'll be.
So, if you want to do it right and not be painting the rusty bits again, get out the grinder, sander, or sand blaster (using appropriate personal and environmental protection gear) and have at it. Have the paint ready and waiting when you've finished grinding.
Also, I've been told it's best to use multi-part paint systems as they chemically bond to the metal and each other. I think it helps if you pick one manufacturer and stick with they're 'system' of primers and topcoats. They're expensive, but I've seen incidents where a manufacturer will refund the product cost when everything is done to their spec and the paint fails. If you mix products (e.g. use POR 15 and then overcoat with an Interlux paint) -- I doubt either POR or Interlux will stand behind the results.
Research the 'paint systems' of Interlux or other well known marine paint companies -- If memory serves, they will have a "paint schedule" for coating iron and steel. Starts with getting the metal bright, then calls for an 'etch primer', then a couple of coats of an epoxy primer and then a top coat, which in the case of a keel will probably be a barrier vinyl coat and then the bottom paint. If you find that you need to fair any divots caused by the rust, the time to do it is between the expoxy primer coats. You apply one coat of primer, then fairing compound --sanded fair, then the second primer coat. (Don't take any of this a gospel -- check it out with the paint supplier, but what's above is probably pretty close to what you'll have to do).
Another place to go for information would be to a commercial boat yard, one that works mostly on metal boats. Ask them what they use and how they go about it.
Done right, you shouldn't have any recurring prolems -- I have a steel hull and I have only a few touch up spots a year below the waterline and a few above -- large sections of the hull have been in the water for over a decade and there's no sign of paint failure or rust.
Old 02-20-2008
Years ago we had an iron keel sandblasted clean as Billy suggests and immediately applied an epoxy sealer to it. This was then sanded once cured, a barrier coating applied and then bottom paint. We've sold the boat since but we didn't see rust again while we owned it.
Our current boat happens to have an iron keel as well.. it too has been sealed and barrier coated. We have not significant indication of rust occuring (so far).
1984 Fast/Nicholson 345
Old 02-20-2008
Lion35 is on a distinguished road
I went through this about 12 years ago and I don't have any rust as of a year ago. We chiped and wire wheeled the keel and then used a converting product that I was told was basically thickend phosporic acid (I can't remeber the name of the product but I'll check my notes when time allows, I thought it was "something or other 45"). We then painted with two part ProLine (recomended from the yard), faired with thickend epoxy, and then barrier coated and bottom painted. It was a heck of a lot of work but it's held up well.
Old 02-20-2008
rperret's Avatar
rperret is on a distinguished road
Most people I have spoken to have had mixed results. I had a Tanzer 22 with an iron keel. After hammering off the rust - and doing some light wire wheel sanding - i used Pettit Rust-Lok - after one season in salt water - there were minor rust spots - mostly small.
Sandblasting is your best option - IMMEDIATELY followed up with a primer/sealant in order to prevent surface rusting that will happen overnite...
May want to look at this site too.
http://www.beneteau235.com/iron_keel_rust.htm
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 17 09-17-2008 04:54 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
