Seacock / Thruhull Replacement quote - Page 2 - SailNet Community
post #11 of 21 Old 02-20-2008
Freesail99's Avatar
Loosen the nuts on the opposite side of the handle, is what I suggested in my first post.
S/V Scheherazade
Freesail99 is offline
post #12 of 21 Old 02-20-2008
Barkeep - Sailor's Pub
craigtoo's Avatar
Send a message via AIM to craigtoo Send a message via Yahoo to craigtoo Send a message via Skype™ to craigtoo
Yeah! ....saw that.. I wasn't clear... I was just offering the vegtable oil idea... but after I re-read it didn't really make sense if you didn't loosen those nuts too so I put it in there... that's all...
craig
-C2
1987 Sabre 34 "Saoirse"
Meet me at the
I love
craigtoo is offline
post #13 of 21 Old 02-20-2008
Replaced 3 gate valves
On my recently purchased 1975 Ericson 27, I replace three thru hulls and gate valves (with ball valves) while she was on the hard.
I too did a TON of research, and eventually became comfortable with the job and went ahead.
It took me time to find the right size thru hulls (online), but the time it took to remove the old thru hulls and install new ones was relatively quick. I'd say my good friend (helper) and I took about 1.5 hours (very cautiously) to replace all three.
Cost of materials (2 brass, 1 marelon) was about $225ish if I recall.
Good luck.
marcusn is offline
post #14 of 21 Old 02-20-2008
I ended up cutting the bronze nuts off with a sawzall, if its in a really bad spot and its the mushroom type or a rawwater intake you can actually cut the mushroom off from the outside being very careful not to shave the hull. On the larger brass thru hulls, like the outflow from the head, I cut them close to the nut from the inside, then put the blade of the sawzall in the hole and cut the brass nut into 2 peices. Works great, just do it super slowly otherwise you will find yourself cutting into fiberglass. It took me about 10 -15 minutes to cut each fitting out.
zakrobinson is offline
post #15 of 21 Old 02-20-2008 Thread Starter
CLucas's Avatar
Send a message via AIM to CLucas
Originally Posted by craigtoo View Post
Hello,
I had the same problem on my boat. 5 of my 6 SeaCocks were frozen. They are the Spartan type you referenced above.
I would offer one suggestion before you bring your guy in. Loosen the nuts on the opposite side of the handle. Plug the hole in the hull with rags / stopper. Pour some vegtable oil in the line (if possible, in my case these were the cockpit drain THulls) and let it sit / soak the Seacock for a few hours. That may free them up. Once free clean and service etc.
I had to contort my body into positions that I never thought possible. But I was able to free all SeaCocks.
Good Luck,
Craig
That's worth a shot -- thanks. At least on one, I successfully loosened the nut opposite the handle. I removed the hose (in this case a galley sink drain), gave a few shots of PB Blaster and let it soak a while (whack it a bit, then repeat the process). Was careful not to remove the retaining nut so I didn't damage the threads and also didn't use a steel hammer. I'm more comfortable doing work on the boat now and perhaps am not as "timid" as I was when I first got the boat.
Good idea, thanks.
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
CLucas is offline
post #16 of 21 Old 02-21-2008
Maine Sail's Avatar
With all due respect..
1) All bronze will eventually turn green when located in a bilge.
2) Spartan marine seacocks, if that's what they are, are perhaps one of the best, and longest lasting, seacocks ever built!
3) They CAN be rebuilt and continue working for many, many years!
4) My neighbor paid $465.00 in just labor to replace two seacocks and that did not include parts.
5) RE-BUILD the Spartans if that is in fact what you have.
6) If it's an old Pearson you may have a thick enough hull to not need backing plates. Still I'm surprised to find someone installing top quality Spartan Marine seacocks without a backing plate.
7) You don't say if these are through bolted or not. This factor will add significant cost if you pay someone to do it.
8) Can you get us a photo of the current installation???
______
-Maine Sail / CS-36T
Maine Sail is offline
post #17 of 21 Old 02-21-2008
I had a frozen seacock of the type shown in the diagram above- loosened nuts and still wouldn't budge, squirted silicone spray or attemted to and still frozen. After wiping the silicone spray away, I then used a butane torch with a 24" hose adapter ($50.00-combined) which allowed me to heat the seacock in the limited access area. the gentle heat and a 18" long with 2-inch inside dia. pipe over the handle of the seacock and pulling very gently, allowed enough movement. This took all of 10-minutes. Once loosened, I was able to completly dissassemble, clean,apply thin coating of winch grease and rebuild within 15-minutes. The culprit was some bottom paint that freezed the seacock. I was able to perform the work since its on the hard, if your boat is in the water, its likely you will have to pay for a haul out. I am not sure what a boat yard would cost but 10-minutes is likely a minimum of one hour. Heat and beat usually works with metal, just how hard you do that is the key,go slow. Hope that helps.
ambianceack is offline
post #18 of 21 Old 02-21-2008
I too enjoy this site and have learned much. Sometimes information is too much "world-view" and too little answer the question asked.
One of my gate valve thru-hulls was replaced Friday in Rock Hall, MD. I spoke with the maintenence supervisor who said they billed for four hours of labor ($ 75.00 and hour), the parts were about $ 125.00.
After reading all the information on this HAD I DONE IT MYSELF I would have made fiberglass backing plates (they used raw plywood). I would have glassed in the plates and used the fitting with the screw holes and put the three bolts thru the hull, glassed them in and painted over them. I would have followed the best ideas at several sites that had the greatest agreement amoung the posters.
I continue to learn that the experience of the sailing community (those who have done work themselves) can provide in-depth "how-to knowledge" and the ability to determine what your own standards are.
My work was paid for by the PO as a condition of sale ($ 475.00). If I did it myself I would have taken longer...done it better...the money saved would have been a bonus. That raw plywood will always bother me.
Dunlookn is offline
post #19 of 21 Old 02-21-2008
I hope the seacocks and through-hulls you bought were BRONZE. Brass should never be used on a boat in an underwater application, unless you're looking to sink the boat. Also, you shouldn't mix metal through-hulls with plastic seacocks.
Good luck.
sailingdog is offline
post #20 of 21 Old 02-22-2008
The problem I had was when I went to remove the frozen valve, it turned the thru hull, thus distroying the thru hull seal. I found a site that hat sold one foot peces of one inch thick marine glued plywood that I glassed in real nice and installed Groco flange adapters. That worked great. I was always told not to put a stright thread in a tapered hole. This corrects it and makes a great strong instilation. the ones on the boat could not have been in more than a turn or two in. Now threads all the way in and with the flange bolted down it will be an easy swap of the valve. I am so happy with it. Much better than the boat yard guy. check it out groco.net/new-prdcts-home/ibvf-08.htm
badsanta is offline
Lubricant for seacock FrankTugw2ell Gear & Maintenance 19 07-07-2011 10:05 PM
Assemble thru-hull & seacock...how? flyhop Gear & Maintenance 10 04-09-2008 05:53 PM
Thruhull replacment on tide grid sailboy21 Gear & Maintenance 11 01-19-2008 10:03 AM
Seacock question saltypat Gear & Maintenance 3 07-21-2007 03:59 PM
seacock replacement in H2o spikenyc Gear & Maintenance 0 06-05-2006 10:08 PM
