02-22-2008
No, it's not a charging thing, it's a battery construction thing. 6V golf cart batteries are "true" deep cycle batteries with very thick all lead plates and can be drawn deeper and supposedly last longer than the typical RV/Marine deep cycle 12V battery. RV/Marine batteries are not "True" deep cycle batteries. They are a combo battery good for house and starting. There are 12V true deep cycel batteries available but they are more expensive and much larger than the 6V batteries. So some folks want the 6V batteries and then wire them in parallel to get 12V.
Me, I've always used the standard 12V RV/Marine batteries as house batteries and never had a problem. My last set lasted 4 years in constant use. There is no secret to this. Keep them charged, check the electrolyte level once a month, check the output voltage and check with a hygrometer occasionally. Keep them clean (dirt can actually drain your batteries). Use a good quality 3 or 4 stage charger and they should last for 4-5 years, maybe longer.
Ike
My Boat building Web Site
My Boating Safety Blog
Dont Tell Me that I can't. Tell me how I can!
