02-29-2008
Hmmm... If the batteries were that low on water, the plates are probably completely shot, since they're probably sulfated, which is what happens when wet cell batteries are operated with low electrolyte levels.
Are you confusing Amps with Volts???
A fully charged 12 VDC battery will register about 12.6 Volts. A fully discharged one will register about 11.6 Volts. It sounds like every time you're saying Amps... you mean Volts.
BTW, generally, batteries that are six years old and have been badly maintained aren't worth even trying to look at.
Originally Posted by wchevron
finally got around to charing the batteries tonight. both batteries were low on water so i filled each one with distilled water. the p.o. had a hydrometer that i found but when i filled it with the battery water, it wouldn't move. i assumed it was broken. one battery was reading 9.6a with the voltmeter. i tried to charge it but no luck. i think it's gone. the second battery starts off at 11A when i first put the voltmeter on it. for the next 10-15 sec the meter fluctuates up and down from 2A to 11A and finally settles on 11A. i put this one on the charger at the 2A charging setting and left it for 3 hours. i just went to check on it. after removing the charger, the voltmeter was reading 13.1A on the battery. i also noticed there was water which looked to have leaked out the caps. maybe the boil off camaraderie had mentioned earlier? does that mean this battery is gone also? both batteries were from 2002.
