02-25-2008
I take it Faster doesn't describe your duck reflexes....
Originally Posted by Faster
In addition, if the prop is "stuck" on, leaving the nut on with some slack will prevent the prop and puller from flying off the shaft at a high rate of knots when it finally lets go. (good idea to stand to the side) Don't ask how I know.......
Loading up the puller and giving the (protected) end of the shaft a sharp tap can often break the prop loose.
