Wiring Diagram Review - Page 3 - SailNet Community
post #21 of 23 Old 02-29-2008
Yes, but they have to be really short lag bolts... HS, you're s a sick and twisted puppy... I can see someone winning a darwin award cause they tried to mount something to the battery case from reading what you wrote... there are some awfully dumb people out there.
Good point about the breaker... I don't know what the surge limit on it is. The situation we were using it in, the surge wasn't really a major concern. The battery wasn't ever going to be used for starting the boat through that wire, since it was a windlass battery, and that was on the wiring going back to the main electrical system for charging the windlass battery. Since it was connected by an ACR unit, and not directly hooked up to the main electrical system, there's never going to be more than 100 amps going through the breaker.
BTW, according to the BlueSea site, those breakers I pointed out are good for up to 3000 Amps surge.
Originally Posted by hellosailor View Post
Those fuse blocks sd posted, can be mounted directly on the battery with size 00 lag bolts, right into the side of the case and through the plates.
KIDDING!
But Scotch exterior-grade double-sided tape, or hot melt glue, or a good adhesive caulk, or the self-adhesive industrial strength velcro, will all make reasonable alternatives. Or you can mount them to a small plate, make a 3/4" hole in it, and let the battery terminal itself stick up through the hole to "anchor" the plate. All sorts of ways.
SD, unless that breaker is one of the special ones that can carry a 5000A surge without fusing shut--it isn't for battery primary service. The conventional breakers all arc shut (useless) with loads around 3500A, and a good battery can put that out into a dead short. The good breakers are damn closed to $100 each.
sailingdog is offline
post #22 of 23 Old 02-29-2008
SD-
I figured, if they used lag bolts and blew themselves up at the dock, I could save them from a painful slow death at sea, so I'd really be doing them a favor, right?
Actually the problem with breakers welding, is that if you drop a wrench across the cables, or something chafes through and grounds, THAT'S when you get get the dead short close enough to the battery to pull 3500+A and weld a breaker. I learned that while I was shopping for breakers, and one of the nice folks who makes them told me "Uh, you really want a fuse for that". Go figure.
Now, if you use really big LONG lag bolts and an air hammer to install them, you can skip those pesky extra battery hold-down straps, and just bolt the whole thing to the outer hull in one shot, can't you?
This is why WalMart stopped selling them home knee-you-clee-er hot water heaters with the rotissery spit attachments, isn't it?
hellosailor is offline
post #23 of 23 Old 02-29-2008
HS-
I want to get a Mr. Fusion for my boat... a lot lighter than all those pesky batteries..... and only a little radiation to worry about.
Yanmar 2QM15 Electrical wiring diagram Nige Gear & Maintenance 1 01-06-2008 06:48 AM
redwing 30 wiring diagram irtrimble C & C 0 12-23-2007 05:08 PM
Yanmar wiring diagram mikethecapt Gear & Maintenance 7 11-22-2007 07:58 PM
Wiring Windlasses SailNet Gear and Maintenance Articles 0 09-19-2002 08:00 PM
Electrical Work Rules Don Casey Gear and Maintenance Articles 0 07-16-2000 08:00 PM
