Originally Posted by Kater
Thanks for all the replies so far!
It's good to hear that many have good experiences with compasses relatively close to a steel deck. This weekend I'll go and try to measure with a hand compass the deviation on various places onboard to see what would be the best spot. The compas I'm aiming at also has an automatic correction, involves going in circles, like mentioned above. So, if the deviation I find isn't to bad, it should be correctable relatively easy.
Now I only have to make a good, waterproof, mounting. And find the best spot. Maybe on a pole on the stern, maybe at the back of the mast under the boom.
Thanks, all.
Hi, Kater! Congratulations on your good taste in boats.
I have several
compasses aboard, and they are functional in different ways.
The helm
compass, mounted on the steel deck, is a Richie Globemaster with the soft iron compensators. Very manly, too. I have to be careful about putting a hammer down beside it, however...it's obviously attuned to its immediate magnetic environment, and doesn't like metallic interlopers. Beautiful instrument, however.
I also have a KVH AC-103 fluxgate
compass, with the sensing head mounted on the aluminum roof of the pilothouse. Compared with the
GPS, the Globemaster's bearing (corrected for variation) with a known bearing from a nav aid to a shore marker, the
GPS, fluxgate and Ritchie all agree. The fluxgate can be used to feed information to an
autopilot, or most
autopilots have a fluxgate you can buy separately.
There is a small teak pad on the lower port spreader that I suspect was the home of a previous
compass sensor.
I, too, do not yet have an
autopilot, but in addition to a wind vane, I am going to get one to drive my hydraulic steering. I plan on getting a ComNav model, probably the simple and straightforward 1001 model:
but I plan on hooking it into a relatively new technology called a Vector G2
GPS Compass, which I will mount atop a hard bimini frame:
Lastly, I have a Suunto Vector "watch" (it does a lot of stuff) that has a remarkably accurate bearing
compass function.
Naturally, I've tried it on the aft deck of the steel boat (where my sailing helm is) and it didn't work well at the usual chest height at which watches are read.
However...when I raised my arm to roughly throat level (or five feet off the deck, as I am six feet tall), the
compass steadied and gave proper readings. So there may be a number of options that don't involve poles or spreaders for the fluxgate you'll eventually want...if you have a non-ferrous pilothouse or bimini, it may be a matter of just testing until you find a spot unaffected by the boat. I would suggest you consult a pro, however, because "swinging" a
compass, even an electronic fluxgate, is a tricky proposition, and you may find through observation that what you think is a reciprocal course is actually 10 degrees off.
Good luck and I hope this helps.
