Anybody tried SeaClear II free nav software? - Page 9 - SailNet Community
 1Likes
post #81 of 105 Old 10-27-2011
TakeFive's Avatar
Originally Posted by Orksail View Post
My Garmin72 GPS(dangled out the window!) is sending NMEA 0185 to SeaClear installed on my desktop PC (Windows 7) so long as I select 4800 baud rate and the correct COM port (which I can read in Devices & Printers). However when I try to do the same on a laptop running Windows XP there is no communication. I connected the Garmin through a USB port in both cases. Do I need to instal a driver with Windows XP?
I can understand why you want to make SeaClear work. OpenCPN is very nice for many applications, but I still like SeaClear better for some things. My 30 day trial with PolarNavy was a disaster. I thought it was very non-intuitive, although YMMV.
The problem you describe is well known for SeaClear, and emanates from the fact that USB is not part of the NMEA standard. For many programs that expect true NMEA, you need a software emulator that is designed to take the USB signal and map it to a COM port. My Garmin Oregon 400c works under SeaClear using Garmin's Spanner software, available for free download. Try that first.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #82 of 105 Old 09-06-2013
LeeV's Avatar
SeaClear II won't recognize my Garmin 76cx
I don't have a serial port available, although I imagine I can find a serial cable for the gps, but I can't understand why SeaClear ii won't recognize usb ports. I can get maps in, etc... but can't hook up this dang gps! Ideas?
LeeV is offline
post #83 of 105 Old 09-06-2013
The most female moderator
Donna_F's Avatar
Dock
Re: Anybody tried SeaClear II free nav software?
SeaClear hasn't been updated or supported in ages. It was created to fill a hole when there was no free nav software available. That's no longer the case. You might want to try a different program. This thread is two years old and the two major software programs (OpenCPN and Polar Navy) have been continually updated and have good customer support.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #84 of 105 Old 09-06-2013
If your GPS has a serial interface you can get an adapter for the computer that will give it a serial port. If your GPS has a USB interface you're out of luck.
whorne is offline
post #85 of 105 Old 09-06-2013
LeeV's Avatar
Thanks for the response. I'm looking at them, but it seems they do not readily connect to a USB driven hand-held gps either!
Thanks,
~LeeV
LeeV is offline
post #86 of 105 Old 09-06-2013
kunkwriter's Avatar
I use it all the time. Bought a usb gps online for five bucks. Need to use the mapcal program inside the downloaded file to put the charts in the program. It's a bit more work then some other programs, but when put on automatic, I find it works as well or better.
kunkwriter is offline
post #87 of 105 Old 09-06-2013
LeeV's Avatar
Let me make sure I understand - you have a gps connected by a USB port and it's communicating with SeaClear?? I have the mapcal part worked out with the charts; I just can't get SeaClear to see my GPS (USB).
LeeV is offline
post #88 of 105 Old 09-07-2013
kunkwriter's Avatar
I have a g-star IV usb gps. The seaclear program reads it automatically as long as it is connected to a usb port on your computer. When I bought a new laptop, I opened the program, plugged in the gps, and it read it again, without me telling it what port. When it's not plugged in it will tell me it can't read from that port, so seaclear begins looking for it. I've never had a problem and use it as my primary nav. I sail the SF bay area and the california coast. I bought the gps on ebay for 6.99. Just looked and they're up to 20 bucks, but that's still cheap.
post #89 of 105 Old 09-07-2013
kunkwriter's Avatar
If it's not reading your gps, maybe go into the tools section, look at the 'comm' tab, and try manually checking the different ports. ONe of them should work.
post #90 of 105 Old 09-07-2013
Over Hill Sailing Club
smurphny's Avatar
Sea Clear is one of the first plotting programs but is pretty limited nowadays. It will only read Raster format, available from NOAA but few other sources. It will not read ENC format. You can create your own raster charts of other areas by using GE pictures but I wouldn't trust these. Almost free is the Polar Navy program which is a great little program for little money.
smurphny is offline
Crew wanted US to Europe/Germany Julian on Cruise Crew Wanted/Available 12 03-15-2011 08:52 PM
Which pocket cruiser is best for me ? dpcolohan Boat Review and Purchase Forum 31 03-02-2008 06:21 PM
