Old 03-01-2008
I'd rather be sailing
labatt will become famous soon enough
Cool butt connectors...
Just saw this link with embedded videos on Navagear.Com ... http://dkc3.digikey.com/PDF/Marketin...orsDSvideo.pdf
Pretty nice stuff.. just for solid core wires though...
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 03-01-2008
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
Those are for splicing telephone wires underground and they work great as such. They eliminate the stripping of the wire, which is nigh on impossible to do on telephone wire anyway! After you've crimped together your nine gazillion wires, you encase all the splices in an exothermic epoxy sealing bag which encases them all in a solid mass of epoxy for sealing and longevity. Don't ask me how I know all about this procedure. And, even if you ask, I'm not going to tell you where I acquired these items for the job.
You'll note that the wire sizes covered are less than 1 mm nominal in size. They will work fine on stranded wire if you twist the ends or leave the ends incased in hteir insulation. Telephone wire is stranded, very finely stranded.
Wm. F. Buckley, Jr.
Old 03-02-2008
mike dryver is on a distinguished road
3M makes those for truck wire connections for i believe up to four wires. they have a silicon grease inside to water proof the connection. we use them on our fleet here in north east and i can tell you since using them we have had no trouble at all with road salt calcium cloride (this stuff is the worst stuff i've seen in 35 yrs of driving as far as causing corrosion related problems ie wiring, frame degradation etc., but these connectors seem to be inpervious to all that can be thrown at them. so i would imagine they would work quite well in the marine enviroment.
Old 03-02-2008
Maine Sail's Avatar
Some concerns..
Some concerns around these connectors would be this; (26-19 AWG) !
Seeing as the ABYC E-11 standard says this regarding DC wiring;
"Conductors shall be at least 16 AWG. EXCEPTIONS: 1. 18 AWG conductors may be used if included with other conductors in a sheath and do not extend more than 30 inches (760mm) outside the sheath.” 11.16.1.1.2."
You would certainly have a very difficult time finding a use for those on a boat with 16ga being the minimum unless you meet the 18ga criteria...
______
-Maine Sail / CS-36T
Old 03-02-2008
Gryzio's Avatar
Spam, Food of the Seagods
Gryzio is on a distinguished road
Interesting and may work for people.
I learned to solder in the early 1980's, learned earlier but really learned in Electronics School.
I guess if I were to use a Butt-Connector I would do the same as when I solder and use a Shrink Wrap to seal the connection.
I really not a Tech Type person, but, usually work during low humidity conditions with electrical. Actually have even played with pulling a vacuum on a system to seal without moisture.
All the rivers run into the sea, yet the sea is not full.
Ecclesiastes, 1:7
Old 03-02-2008
theartfuldodger's Avatar
theartfuldodger is an unknown quantity at this point
Send a message via Skype™ to theartfuldodger
have tried them and they don't work, there is no moisture seanant, still the best is butt's covered in shrink wrap with sealant
The Artful Dodger II
NFLD and Labrador
33 Morgan O/I
Very Cool, compare any 2 sailboats to each other NewsReader Mass Bay Sailors 0 04-09-2007 04:15 PM
electrical butt connectors GarrettK Gear & Maintenance 3 11-15-2004 12:57 PM
