tohatsu 3.5 won't run without choking - Page 2 - SailNet Community
 1Likes
post #11 of 65 Old 03-03-2008 Thread Starter
Hi,
Thanks for the responses!
No wheezing. After I throttle up, it sounds like it is starving for gas.
It was only a few weeks between runnings, so gas was good. Vent was open
I did visually verify operation of the choke/throttle yesterday, so that's not it. New plug/oil/fuel yesterday -- same problem.
The outside of the carb has a small amount of varnish(likely from old spillage), but not much. The (new) plug was very slightly darkened after a few minutes of running, but not fouled or burned, so that looks OK.
Disassembling the carb is likely in my future. I'll let you know what I find! If I do destroy the gaskets, any recommendation on where to order replacements?
jshep is offline
post #12 of 65 Old 03-03-2008
moderate?
camaraderie's Avatar
camaraderie is offline
post #13 of 65 Old 03-03-2008
Misanthrope
TohatsuGuru's Avatar
You have a 99.99% chance of the carburetor orifices being clogged up. You will have to remove the carburetor and disassemble it before dipping the body and metal parts in carburetor cleaner. Under no circumstances can you place the plastic, rubber or fiber parts in cleaner as that will either dissolve them or cause them to swell. Any Nissan, Tohatsu or Mercury dealer has parts for this model engine.
Elvin
Solution One Maritime
TohatsuGuru is offline
post #14 of 65 Old 03-03-2008
"Nevis Nice"
hphoen's Avatar
My last two outboards have been Nissan and Tohatsu, both made by Tohatsu. They have been absolutely great in starting. The only time I had any problems was when I used "old" fuel--three months old. Went to the fresh stuff, and it fired right up. Make sure your gas is new!
Hud
hphoen is offline
post #15 of 65 Old 03-03-2008
Owner, Green Bay Packers
You say the fuel flow is good. I'd change the fuel filter anyway. Don't ask me how I know this.
Wm. F. Buckley, Jr.
sailaway21 is offline
post #16 of 65 Old 03-18-2008 Thread Starter
fixed!
Well, as suspected it was a piece of gunk clogging the jet inside of the bowl. All cleaned and runs great.
The wirewrap wire was a tool that worked great too.
Thanks for the advice!
jshep is offline
post #17 of 65 Old 03-19-2008
moderate?
Thanks for the follow up report. It is always good to know if diagnosis and suggested fixes pan out. Glad yer back up and running!
post #18 of 65 Old 03-20-2008
Esconditas's Avatar
Does it have a fuel pump? My 15 hp Nissan was doing that and it turned out to be the fuel pump, Which is a rubber sheet with one side being connected to the crankcase (making it flutter as the engine runs) and the other side having a set of one way valves. There was a leak around the sheet and it wasn't sealed to the crankcase and didn't flutter. Took it apart put some gasket sealer around the edge, put it back together, and boom it worked.
Esconditas is offline
post #19 of 65 Old 03-20-2008
Armchair Horn Sailor
Alden68's Avatar
Jshep and all:
As Chuckles pointed out there is a real problem with E85 and your dink motor.
My Merc is 2 years old and wouldn't run without the choke. Had to have the carb rebuilt and the mech said "let me guess....you fill up a 5 gall tank in your dink and it sits there all season." Yup. Well the ethanol causes the gas to separate as it just sits around and this was contaminating my carb. He suggested only using .5 to a gallon at a time. More trips to the gas station but fewer trips to see him!
Alden68 is offline
post #20 of 65 Old 03-22-2008
NautiG's Avatar
Running the engine dry (ie disconnecting the fuel line, or shutting off the fuel valve) would also probably help in preventing the carb from getting clogged. I have a couple two cycle engines, and I try to shut them off by cutting off the fuel supply, instead of turning the on/off switch. Especially if I know the engine is going to sit awhile without use.
Scott
Gemini Catamaran Split Decision
Captain's Blog
NautiG is offline
Nissan / Tohatsu 6h 4 stroke audeojude Outboard 261 09-08-2015 05:59 PM
New Dink, Looking at Tohatsu 3.5 Sapperwhite Gear & Maintenance 43 06-30-2009 06:38 AM
Make offer or run away? eherlihy Boat Review and Purchase Forum 56 10-03-2007 02:36 PM
Refrigeration—Part II Selecting a System Tom Wood Gear and Maintenance Articles 0 05-19-2003 08:00 PM
What to Do When You Run Aground Sue & Larry Her Sailnet Articles 0 12-18-2002 07:00 PM
